Клеммники KEEN SIDE
Datasheet ATUC64D3-A2UT - Atmel Даташит Микроконтроллеры (MCU) UC3D3 64 Кб FL 85C — Даташит
Наименование модели: ATUC64D3-A2UT
Микросхема Микроконтроллер 32, ATMEL ATUC64D3-A2UT 32Bit Microcontroller, SAM D Series, AVR32, 48MHz, 64KB, 16KB, 64Pins, TQFP
ATUC64D3-A2UT
125 ₽
ATUC64D3-A2UT
237 ₽
ATUC64D3-A2UT
Atmel
273 ₽
ATUC64D3-A2UT
343 ₽
Производитель: Atmel
Описание: Микроконтроллеры (MCU) UC3D3 64 Кб FL 85C
data sheetСкачать Data Sheet
Features
· High Performance, Low Power 32-bit AVR® Microcontroller
­ Compact Single-Cycle RISC Instruction Set Including DSP Instructions ­ Read-Modify-Write Instructions and Atomic Bit Manipulation ­ Performance · Up to 61 DMIPS Running at 48MHz from Flash (1 Flash Wait State) · Up to 34 DMIPS Running at 24MHz from Flash (0 Flash Wait State) Multi-Hierarchy Bus System ­ High-Performance Data Transfers on Separate Buses for Increased Performance ­ 7 Peripheral DMA Channels Improve Speed for Peripheral Communication Internal High-Speed Flash ­ 128Kbytes, and 64Kbytes Versions ­ Single-Cycle Access up to 24MHz ­ Prefetch Buffer Optimizing Instruction Execution at Maximum Speed ­ 4ms Page Programming Time and 8ms Full-Chip Erase Time ­ 100,000 Write Cycles, 15-year Data Retention Capability ­ Flash Security Locks and User Defined Configuration Area Internal High-Speed SRAM, Single-Cycle Access at Full Speed ­ 16Kbytes Interrupt Controller (INTC) ­ Autovectored Low Latency Interrupt Servic
  • Упаковка: Tray
  • RoHS: да
ATUC64D3A2UT, ATUC64D3 A2UT
На английском языке: Datasheet ATUC64D3-A2UT - Atmel Microcontrollers (MCU) UC3D3 64 Kb FL 85C
