Datasheet ATXMEGA32D4-CUR - Atmel Даташит Микроконтроллеры (MCU) 32 Кб FL 1 Кб EE 4K SRAM IND 1.6-3.6 В — Даташит
Наименование модели: ATXMEGA32D4-CUR
14 предложений от 12 поставщиков
Микросхема Микроконтроллер, MCU 8Bit/16Bit XMEGA AVR RISC 32KB Flash 1.8V/2.5V/3.3V 49Pin VFBGA T/R
ATXMEGA32D4-CUR
123 ₽
ATXMEGA32D4-CUR
327 ₽
Hi-Tech Circuit Group
ATXMEGA32D4-CUR
LifeElectronics
ATXMEGA32D4-CUR
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 32 Кб FL 1 Кб EE 4K SRAM IND 1.6-3.6 В
data sheetСкачать Data Sheet
Features
· High-performance, Low-power 8/16-bit Atmel® AVR® XMEGA® Microcontroller · Non-volatile Program and Data Memories
­ 16 KB - 128 KB of In-System Self-Programmable Flash ­ 4 KB - 8 KB Boot Code Section with Independent Lock Bits ­ 1 KB - 2 KB EEPROM ­ 2 KB - 8 KB Internal SRAM Peripheral Features ­ Four-channel Event System ­ Four 16-bit Timer/Counters Three Timer/Counters with 4 Output Compare or Input Capture channels One Timer/Counter with 2 Output Compare or Input Capture channels High-Resolution Extensions on two Timer/Counters Advanced Waveform Extension on one Timer/Counter ­ Two USARTs IrDA Extension on one USART ­ Two Two-Wire Interfaces with dual address match (I2C and SMBus compatible) ­ Two SPIs (Serial Peripheral Interfaces) peripherals ­ 16-bit Real Time Counter with Separate Oscillator ­ One Twelve-channel, 12-bit, 200 ksps Analog to Digital Converter ­ Two Analog Comparators with Window compare function ­ External Interrupts on all General Purpose I/O pins ­ Pro
  • Упаковка: Reel
  • RoHS: да
ATXMEGA32D4CUR, ATXMEGA32D4 CUR
На английском языке: Datasheet ATXMEGA32D4-CUR - Atmel Microcontrollers (MCU) 32 Kb FL 1 Kb EE 4K SRAM IND 1.6-3.6 V
