Datasheet ATXMEGA16D4-CUR - Atmel Даташит Микроконтроллеры (MCU) 16 Кб FL 1 Кб EE 2K SRAM IND 1.6-3.6 В — Даташит
Наименование модели: ATXMEGA16D4-CUR
![]() 9 предложений от 9 поставщиков Микросхема Микроконтроллер, MCU 8Bit/16Bit XMEGA AVR RISC 16KB Flash 1.8V/2.5V/3.3V 49Pin VFBGA T/R | |||
ATXMEGA16D4-CUR Atmel | 124 ₽ | ||
ATXMEGA16D4-CUR Microchip | 317 ₽ | ||
ATXMEGA16D4-CUR Microchip | по запросу | ||
ATXMEGA16D4-CUR Atmel | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 16 Кб FL 1 Кб EE 2K SRAM IND 1.6-3.6 В
Features
· High-performance, Low-power 8/16-bit Atmel® AVR® XMEGA® Microcontroller · Non-volatile Program and Data Memories
16 KB - 128 KB of In-System Self-Programmable Flash 4 KB - 8 KB Boot Code Section with Independent Lock Bits 1 KB - 2 KB EEPROM 2 KB - 8 KB Internal SRAM Peripheral Features Four-channel Event System Four 16-bit Timer/Counters Three Timer/Counters with 4 Output Compare or Input Capture channels One Timer/Counter with 2 Output Compare or Input Capture channels High-Resolution Extensions on two Timer/Counters Advanced Waveform Extension on one Timer/Counter Two USARTs IrDA Extension on one USART Two Two-Wire Interfaces with dual address match (I2C and SMBus compatible) Two SPIs (Serial Peripheral Interfaces) peripherals 16-bit Real Time Counter with Separate Oscillator One Twelve-channel, 12-bit, 200 ksps Analog to Digital Converter Two Analog Comparators with Window compare function External Interrupts on all General Purpose I/O pins Pro
- Размер ОЗУ: 16 Кб
- Размер памяти программ: 16 Кб
- Упаковка: Reel
- RoHS: да
ATXMEGA16D4CUR, ATXMEGA16D4 CUR
