Datasheet Texas Instruments LM3S6637-IBZ50-A2T — Даташит
СерияLM3S6637
МодельLM3S6637-IBZ50-A2T
Микроконтроллер Stellaris LM3S 108-NFBGA от -40 до 85
Stellaris LM3S6637 Microcontroller Data Sheet datasheet
PDF, 4.7 Мб, Версия: I, Файл опубликован: 16 июл 2014
Pin108108108
Package TypeZCRZCRZCR
Industry STD TermNFBGANFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-N
Package QTY100010001000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаZCRIBZ50LM3S6637
Width (мм)101010
Length (мм)101010
Thickness (мм).95.95.95
Pitch (мм).8.8.8
Max Height (мм)1.51.51.5
  • Serial-to-Ethernet Converter for Stellaris Microcontrollers (AN01266)
    PDF, 89 Кб, Файл опубликован: 7 июл 2009
    The software described in this application note allows an Ethernet-enabled Stellaris microcontroller to be used as a serial-to-Ethernet converter.
  • Using the Stellaris Ethernet Controller with Lightweight IP (lwIP) (AN01261) (Rev. C)
    PDF, 70 Кб, Версия: C, Файл опубликован: 8 сен 2012
  • Migrating from Sandstorm-Class to Fury-Class Stellaris Microcontrollers
    PDF, 184 Кб, Файл опубликован: 7 июл 2009
    This application note provides a summary of differences between existing Sandstorm class devices and new Fury class devices in the Stellaris family of microcontrollers.
  • Using the Stellaris Ethernet Controller with Micro IP (uIP) (AN01260) (Rev. B)
    PDF, 128 Кб, Версия: B, Файл опубликован: 11 янв 2010
    This application note gives an overview of the uIP TCP/IP stack followed by a discussion of uIP application examples provided for Stellaris evaluation boards with Ethernet controllers.
  • MODBUS Bridge using Stellaris
    PDF, 313 Кб, Файл опубликован: 3 ноя 2011
    This application report describes the implementation of the MODBUS bridge using StellarisВ® microcontrollers. The idea is to add the functionality of converting MODBUS TCP packets into MODBUS Serial packets on the MDL-S2E, which can be used to interface existing MODBUS Serial devices to Ethernet.
LM3S6637IBZ50A2T, LM3S6637 IBZ50 A2T
На английском языке: Datasheet Texas Instruments LM3S6637-IBZ50-A2T
