Datasheet ATMEGA32U4RC-MUR - Atmel Даташит Микроконтроллеры (MCU) AVR USB 16K FL 16 МГц Ind Temp Grn — Даташит
Наименование модели: ATMEGA32U4RC-MUR
IC MCU 8BIT 32KB FLASH 44VQFN. AVR AVR® ATmega Microcontroller IC 8-Bit 16MHz 32KB (16K x 16) FLASH 44-VQFN (7x7). Embedded...
ATMEGA32U4RC-MUR
5 724 ₽
ATMEGA32U4RC-MUR
Atmel
727GS
ATMEGA32U4RC-MUR
ATMEGA32U4RC-MUR
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR USB 16K FL 16 МГц Ind Temp Grn
data sheetСкачать Data Sheet
Features
· High Performance, Low Power AVR® 8-Bit Microcontroller · Advanced RISC Architecture
­ 135 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 16 MIPS Throughput at 16 MHz ­ On-Chip 2-cycle Multiplier Non-volatile Program and Data Memories ­ 16/32K Bytes of In-System Self-Programmable Flash (ATmega16U4/ATmega32U4) ­ 1.25/2.5K Bytes Internal SRAM (ATmega16U4/ATmega32U4) ­ 512Bytes/1K Bytes Internal EEPROM (ATmega16U4/ATmega32U4) ­ Write/Erase Cycles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/ 100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation All supplied parts are preprogramed with a default USB bootloader ­ Programming Lock for Software Security JTAG (IEEE std.
1149.1 compliant) Interface ­ Boundary-scan Capabilities According to the JTAG Standard ­ Extensive On-chip Debu
  • Ядро: AVR8
  • RoHS: да
ATMEGA32U4RCMUR, ATMEGA32U4RC MUR
На английском языке: Datasheet ATMEGA32U4RC-MUR - Atmel Microcontrollers (MCU) AVR USB 16K FL 16 MHz Ind Temp Grn
