Datasheet Texas Instruments CC430F6137IRGCR — Даташит
СерияCC430F6137
МодельCC430F6137IRGCR
16-битный микроконтроллер со сверхнизким энергопотреблением, 32 КБ флэш-памяти, 4 КБ ОЗУ, радио CC1101, AES-128, 12-битный АЦП, USCI, драйвер ЖК-дисплея 64-VQFN от -40 до 85
CC430F613x, CC430F612x, CC430F513x MSP430 SoC With RF Core datasheet
PDF, 2.0 Мб, Версия: H, Файл опубликован: 6 сен 2013
Pin64
Package TypeRGC
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2000
МаркировкаCC430F6137
Width (мм)9
Length (мм)9
Thickness (мм).88
Pitch (мм).5
Max Height (мм)1
  • Evaluation Modules & Boards: EZ430-CHRONOS
    Chronos: Wireless development tool in a watch
  • Evaluation Modules & Boards: MSP-EXPCC430RFX
    CC430 Sub-GHz RF Experimenter’s Board
  • Evaluation Modules & Boards: MSP-SA430-SUB1GHZ
    Sub-1 GHz RF Spectrum Analyzer Tool
  • CC430 Wake-On-Radio Functionality (Rev. A)
    PDF, 210 Кб, Версия: A, Файл опубликован: 10 июл 2012
    The Wake-On-Radio (WOR) feature of the CC430 is a recommended method for conserving power in wireless systems in which the radio periodically wakes up from SLEEP mode and listens for incoming packets. This application note describes the theory, RF1A registers, and timing of the WOR feature. It also describes the special use case of the CC430F61xx and CC430F51xx devices. This application note concl
  • AN088 -- SimpliciTI on the CC430 – Practical Modifications
    PDF, 89 Кб, Файл опубликован: 10 мар 2010
  • CC430 RF Examples (Rev. C)
    PDF, 117 Кб, Версия: C, Файл опубликован: 7 сен 2012
    This application report describes the library components and implementation of the RF code examples for the CC430F61xx and CC430F51xx sub-1GHz system-on-chip (SoC) devices. The examples include support for packet-handling modes, including variable and fixed length filtering, as well as the asynchronous and synchronous modes of communication. The document also explains the key RF configuration regi
  • CC430-Based Wireless Mesh Network Mains Switch
    PDF, 966 Кб, Файл опубликован: 20 май 2011
    This application report describes a simple wireless mesh network running on a number of wireless power points. Each power point contains a timer switch and a power monitor. The mesh network is self learning. A data concentrator works through the various power points it discovers and forms a network. It can then program the on/off timing of the power point's switch and monitor its power consumption
  • Using a DC-DC Converter to Reduce Power (Current) Consumption In CC430 Systems
    PDF, 4.6 Мб, Файл опубликован: 5 июл 2011
    This application report describes a method to reduce power consumption in CC430-based systems by using a step-down converter TPS62730.
  • AN072 -- Using the TAI-SAW TA0801A SAW Filter and External PA (Rev. A)
    PDF, 359 Кб, Версия: A, Файл опубликован: 19 авг 2009
  • AN050 -- Using the CC1101 in the European 868MHz SRD band (Rev. B)
    PDF, 223 Кб, Версия: B, Файл опубликован: 11 сен 2009
  • DN508 -- Frequency Scanning using CC430Fx, CC110x, and CC111xFx
    PDF, 65 Кб, Файл опубликован: 25 янв 2010
    The purpose of this design note is to show the necessary steps to successfully scan through a frequency band covering n numbers of channels, and find the strongest signal in the band.
  • DN005 -- CC11xx Sensitivity versus Frequency Offset and Crystal Accuracy (Rev. C)
    PDF, 96 Кб, Версия: C, Файл опубликован: 20 авг 2009
  • DN022 -- CC110x CC111x OOK ASK Register Settings (Rev. E)
    PDF, 532 Кб, Версия: E, Файл опубликован: 8 мар 2012
  • DN032 -- Options for Cost Optimized CC11xx Matching
    PDF, 112 Кб, Файл опубликован: 25 авг 2010
  • DN016 -- Compact Antenna Solution for 868/915 MHz (Rev. B)
    PDF, 832 Кб, Версия: B, Файл опубликован: 20 авг 2009
  • DN019 -- Powering Low-Power RF Products (Rev. B)
    PDF, 327 Кб, Версия: B, Файл опубликован: 18 сен 2009
  • DN507 -- FEC Decoding
    PDF, 264 Кб, Файл опубликован: 28 янв 2010
    The purpose of this design note is to show how the FEC decoding implemented in HW on the CC1100, CC1100E, CC1101, CC1110Fx, CC1111Fx, CC1150, CC2500, CC2510Fx, CC2511Fx, and CC2550 can be implemented in SW. This is in particular very important for the CC430Fx device, which has the same radio as the CC1101 and CC1110/11Fx but without HW FEC included.
  • DN024 -- 868 MHz, 915 MHz and 955 MHz Monopole PCB Antenna (Rev. E)
    PDF, 1.0 Мб, Версия: E, Файл опубликован: 22 фев 2013
  • DN502 -- CRC Implementation (Rev. D)
    PDF, 55 Кб, Версия: D, Файл опубликован: 27 окт 2009
  • AN001 -- SRD regulations for license free transceiver operation
    PDF, 260 Кб, Файл опубликован: 1 фев 2006
  • DN033 - Mitsubishi Ceramic Antenna for 868 MHz, 915 MHz & 955 (Rev. A)
    PDF, 685 Кб, Версия: A, Файл опубликован: 14 сен 2010
  • DN023 -- 868 MHz, 915 MHz and 955 MHz Inverted F Antenna (Rev. C)
    PDF, 369 Кб, Версия: C, Файл опубликован: 30 авг 2011
  • DN018 -- Range Measurements in an Open Field Environment (Rev. A)
    PDF, 607 Кб, Версия: A, Файл опубликован: 15 апр 2008
    This design note is a general description of how to set up open field range measurements and what has to be considered. Applies to all low power RF-ICs.
  • DN002 -- Practical Sensitivity Testing
    PDF, 364 Кб, Файл опубликован: 20 дек 2006
  • AN003 -- SRD Antennas
    PDF, 358 Кб, Файл опубликован: 1 фев 2006
  • DN000 - Design Note Overview (Rev. T)
    PDF, 126 Кб, Версия: T, Файл опубликован: 12 окт 2011
  • DN031 -- CC-Antenna-DK Documentation and Antenna Measurements Summary
    PDF, 2.3 Мб, Файл опубликован: 26 авг 2010
    DN031 -- Design Notes
  • AN058 -- Antenna Selection Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 окт 2010
  • Using the USCI I2C Master (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 11 мар 2015
    This document describes how to use the I2C master function set for MSP430в„ў devices with the USCI module. These functions can be used by MSP430 master devices to ensure proper initialization of the USCI module and provide I2C transmit and receive functionality. A similar version with DMA support has also been included. The USCI I2C master function set only supports single-master transmitter or rece
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
  • ESD Diode Current Specification
    PDF, 520 Кб, Файл опубликован: 7 дек 2015
    This document explains the maximum ESD diode current specified for GPIO on MSP microcontrollers. Sometimes signals on specific pins exceed the supply of the MSP MCU. In such a case, the device can handle this overvoltage condition through the ESD diodes, but the ESD diode specification must be considered during application design. The items to be considered are described in this document.
  • Design Considerations When Using the MSP430 Graphics Library
    PDF, 475 Кб, Файл опубликован: 5 окт 2012
    LCDs are a growing commodity in todays market with products as diverse as children's toys to medical devices. Modern LCDs, along with the graphics displayed on them, are growing in complexity. A graphics library can simplify and accelerate development while creating the desired user experience. TI provides the MSP430 Graphics Library for use in developing products with the MSP430в„ў MCU. This
  • MSP Code Protection Features
    PDF, 752 Кб, Файл опубликован: 7 дек 2015
    MSP microcontrollers (MCUs) offer a number of features to help control code accessibility in the device, to add different layers of code access management and protection strategies. These include features that can lock or password protect the JTAG/SBW access, IP Encapsulation (IPE) to isolate sensitive code with different permissions than the rest of the program, and bootloader (BSL) access featur
Серия: CC430F6137 (2)
  • Semiconductors > Microcontrollers (MCU) > Other Microcontrollers > CC430
На английском языке: Datasheet Texas Instruments CC430F6137IRGCR
