Datasheet ATMEGA168P-20AN - Atmel Даташит Микроконтроллеры (MCU) 16 Кб FLASH 512B EE 1 Кб SRAM - 20 МГц — Даташит
Наименование модели: ATMEGA168P-20AN
IC MCU 8BIT 16KB FLASH 32TQFP. AVR AVR® ATmega Microcontroller IC 8-Bit 20MHz 16KB (8K x 16) FLASH 32-TQFP (7x7). Embedded...
ATMEGA168P-20AN
321 ₽
Эиком
ATMEGA168P-20AN
от 703 ₽
Hi-Tech Circuit Group
ATMEGA168P-20AN
ATMEGA168P-20AN
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 16 Кб FLASH 512B EE 1 Кб SRAM - 20 МГц
data sheetСкачать Data Sheet
Features
· High Performance, Low Power Atmel® AVR® 8-Bit Microcontroller · Advanced RISC Architecture
­ 131 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 20 MIPS Throughput at 20 MHz ­ On-chip 2-cycle Multiplier High Endurance Non-volatile Memory Segments ­ 4/8/16K Bytes of In-System Self-Programmable Flash progam memory ­ 256/512/512 Bytes EEPROM ­ 512/1K/1K Bytes Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ Programming Lock for Software Security Peripheral Features ­ Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode ­ One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode ­ Real Time Counter with Separate Oscillator ­ Six PWM Channels ­ 8-channel 10
  • Серия процессора: ATMEGA16x
  • Шина данных: 8 бит
  • Ядро: AVR8
  • RoHS: да
ATMEGA168P20AN, ATMEGA168P 20AN
На английском языке: Datasheet ATMEGA168P-20AN - Atmel Microcontrollers (MCU) 16 Kb FLASH 512B EE 1 Kb SRAM - 20 MHz
