Datasheet ATMEGA168PV-10AN - Atmel Даташит Микроконтроллеры (MCU) 16 Кб FLASH 512B EE 1 Кб SRAM - 10 МГц — Даташит
Наименование модели: ATMEGA168PV-10AN
Купить ATMEGA168PV-10AN на РадиоЛоцман.Цены — от 81 до 348 ₽12 предложений от 12 поставщиков IC MCU 8BIT 16KB FLASH 32TQFP. AVR AVR® ATmega Microcontroller IC 8-Bit 10MHz 16KB (8K x 16) FLASH 32-TQFP (7x7). Embedded... | |||
| ATMEGA168PV-10AN Atmel | 81 ₽ | ||
| ATMEGA168PV-10AN Rochester Electronics | 249 ₽ | ||
| ATMEGA168PV-10AN Atmel | по запросу | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 16 Кб FLASH 512B EE 1 Кб SRAM - 10 МГц
Features
· High Performance, Low Power Atmel® AVR® 8-Bit Microcontroller · Advanced RISC Architecture
131 Powerful Instructions Most Single Clock Cycle Execution 32 x 8 General Purpose Working Registers Fully Static Operation Up to 20 MIPS Throughput at 20 MHz On-chip 2-cycle Multiplier High Endurance Non-volatile Memory Segments 4/8/16KBytes of In-System Self-Programmable Flash progam memory 256/512/512Bytes EEPROM 512/1K/1KBytes Internal SRAM Write/Erase Cycles: 10,000 Flash/100,000 EEPROM Data retention: 20 years at 85°C/100 years at 25°C(1) Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation Programming Lock for Software Security QTouch® library support Capacitive touch buttons, sliders and wheels QTouch and QMatrix acquisition Up to 64 sense channels Peripheral Features Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode One 16-bit Timer/Counter with Se
- Серия процессора: ATMEGA16x
- Шина данных: 8 бит
- Ядро: AVR8
- RoHS: да
ATMEGA168PV10AN, ATMEGA168PV 10AN
