Datasheet Texas Instruments LM3S2B93-IBZ80-C5T — Даташит
СерияLM3S2B93
МодельLM3S2B93-IBZ80-C5T
Микроконтроллер Stellaris LM3S 108-NFBGA от -40 до 85
Stellaris LM3S2B93 Microcontroller Data Sheet datasheet
PDF, 6.8 Мб, Версия: O, Файл опубликован: 3 июл 2014
Pin108108
Package TypeZCRZCR
Industry STD TermNFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-N
МаркировкаLM3S2B93IBZ80
Width (мм)1010
Length (мм)1010
Thickness (мм).95.95
Pitch (мм).8.8
Max Height (мм)1.51.5
RoHSНе совместим
  • Using AES Encryption and Decryption with Stellaris Microcontrollers (AN01251) (Rev. B)
    PDF, 113 Кб, Версия: B, Файл опубликован: 8 янв 2010
    This application note describes the following four encryption methods used with AES: Electronic code book (ECB), cipher block chaining (CBC) or chained encryption, cipher feedback (CFB), and counter (CTR). These methods are described in more detail to help you select the appropriate method(s) for your application. The encryption package described in this application note is available with full sou
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
LM3S2B93IBZ80C5T, LM3S2B93 IBZ80 C5T
На английском языке: Datasheet Texas Instruments LM3S2B93-IBZ80-C5T
