Datasheet ATMEGA32A-AN - Atmel Даташит Микроконтроллеры (MCU) AVR 32 Кб FL 1 Кб EE 2 Кб SRAM 16 МГц Grn — Даташит
Наименование модели: ATMEGA32A-AN
25 предложений от 14 поставщиков
IC MCU 8BIT 32KB FLASH 44TQFP / AVR AVR? ATmega Microcontroller IC 8-Bit 16MHz 32KB (16K x 16) FLASH 44-TQFP (10x10)...
ATMEGA32A-AN
Atmel
80 ₽
ATMEGA32A-AN
347 ₽
ATMEGA32A-AN
Atmel
366 ₽
Элитан
ATMEGA32A-AN
732 ₽
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 32 Кб FL 1 Кб EE 2 Кб SRAM 16 МГц Grn
data sheetСкачать Data Sheet
Features
· High-performance, Low-power Atmel® AVR® 8-bit Microcontroller · Advanced RISC Architecture
­ 131 Powerful Instructions ­ Most Single-clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 16 MIPS Throughput at 16 MHz ­ On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments ­ 32 Kbytes of In-System Self-programmable Flash program memory ­ 1024 Bytes EEPROM ­ 2 Kbyte Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ Programming Lock for Software Security JTAG (IEEE std.
1149.1 Compliant) Interface ­ Boundary-scan Capabilities According to the JTAG Standard ­ Extensive On-chip Debug Support ­ Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface Peripheral Features ­ Two 8-bit Timer/Counters wi
  • Ядро: AVR8
  • RoHS: да
ATMEGA32AAN, ATMEGA32A AN
На английском языке: Datasheet ATMEGA32A-AN - Atmel Microcontrollers (MCU) AVR 32 Kb FL 1 Kb EE 2 Kb SRAM 16 MHz Grn
