Datasheet AT90PWM3B-16SUR - Atmel Даташит Микроконтроллеры (MCU) 8 Кб FLASH 512B EE 512B RAM 16 МГц — Даташит
Наименование модели: AT90PWM3B-16SUR
![]() 11 предложений от 11 поставщиков Микросхема Микроконтроллер, MCU 8Bit AT90 AVR RISC 8KB Flash 3.3V/5V 32Pin SOIC T/R | |||
AT90PWM3B-16SUR Microchip | 144 ₽ | ||
AT90PWM3B-16SUR Atmel | 392 ₽ | ||
AT90PWM3B16SUR | 142 124 ₽ | ||
AT90PWM3B-16SUR Atmel | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 8 Кб FLASH 512B EE 512B RAM 16 МГц
Features
· High Performance, Low Power Atmel® AVR® 8-bit Microcontroller · Advanced RISC Architecture
129 Powerful Instructions - Most Single Clock Cycle Execution 32 x 8 General Purpose Working Registers Fully Static Operation Up to 1 MIPS throughput per MHz On-chip 2-cycle Multiplier Data and Non-Volatile Program Memory 8K Bytes Flash of In-System Programmable Program Memory · Endurance: 10,000 Write/Erase Cycles Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation 512 Bytes of In-System Programmable EEPROM Endurance: 100,000 Write/Erase Cycles 512 Bytes Internal SRAM Programming Lock for Flash Program and EEPROM Data Security On Chip Debug Interface (debugWIRE) Peripheral Features Two or three 12-bit High Speed PSC (Power Stage Controllers) with 4-bit Resolution Enhancement · Non Overlapping Inverted PWM Output Pins With Flexible Dead-Time · Variable PWM duty Cycle and Frequency · Sy
- Вид монтажа: SMD/SMT
- Тип корпуса: SOIC
- Упаковка: Reel
- Шина данных: 8 бит
- RoHS: да
AT90PWM3B16SUR, AT90PWM3B 16SUR
