Datasheet AT32UC3A4256S-C1UT - Atmel Даташит Микроконтроллеры (MCU) 256k flash Ind — Даташит
Наименование модели: AT32UC3A4256S-C1UT
![]() 16 предложений от 15 поставщиков IC MCU 32BIT 256KB FLASH 100BGA. AVR AVR®32 UC3 A4 Microcontroller IC 32-Bit 66MHz 256KB (256K x 8) FLASH 100-VFBGA (7x7).... | |||
AT32UC3A4256S-C1UT Microchip | 533 ₽ | ||
AT32UC3A4256S-C1UT Atmel | 1 054 ₽ | ||
AT32UC3A4256S-C1UT Atmel | по запросу | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 256k flash Ind
Features
· High Performance, Low Power 32-bit AVR® Microcontroller
Compact Single-Cycle RISC Instruction Set Including DSP Instruction Set Read-Modify-Write Instructions and Atomic Bit Manipulation Performing up to 1.51DMIPS/MHz · Up to 92DMIPS Running at 66MHz from Flash (1 Wait-State) · Up to 54 DMIPS Running at 36MHz from Flash (0 Wait-State) Memory Protection Unit Multi-Layer Bus System High-Performance Data Transfers on Separate Buses for Increased Performance 8 Peripheral DMA Channels (PDCA) Improves Speed for Peripheral Communication 4 generic DMA Channels for High Bandwidth Data Paths Internal High-Speed Flash 256KBytes, 128KBytes, 64KBytes versions Single-Cycle Flash Access up to 36MHz Prefetch Buffer Optimizing Instruction Execution at Maximum Speed 4 ms Page Programming Time and 8ms Full-Chip Erase Time 100,000 Write Cycles, 15-year Data Retention Capability Flash Security Locks and User Defined Configuration Area Internal High-Speed SRAM 64KBytes
- Упаковка: Tray
- Ядро: AVR32
- RoHS: да
AT32UC3A4256SC1UT, AT32UC3A4256S C1UT
