Datasheet ATA6622-PGQW - Atmel Даташит Микроконтроллеры (MCU) LIN Networking System Basis Chip — Даташит
Atmel ATA6622-PGQW
Наименование модели: ATA6622-PGQW
IC TRANSCEIVER 1/1 20QFN. 1/1 Transceiver LINbus 20-QFN (5x5). Interface - Drivers, Receivers, Transceivers
ATA6622-PGQW
63 ₽
Рутоника
ATA6622-PGQW
ATA6622-PGQW
Hi-Tech Circuit Group
ATA6622-PGQW
Производитель: Atmel
Описание: Микроконтроллеры (MCU) LIN Networking System Basis Chip
data sheetСкачать Data Sheet
Atmel ATA6622/ATA6624/ATA6626 Atmel ATA6622C/ATA6624C/ATA6626C
LIN Bus Transceiver with 3.3V (5V) Regulator and Watchdog
DATASHEET Features
Master and slave operation possible Supply voltage up to 40V Operating voltage VS = 5V to 27V Typically 10µA supply current during Sleep Mode Typically 57µA supply current in Silent Mode Linear low-drop voltage regulator, 85mA current capability: Normal, Fail-safe, and Silent Mode Atmel ATA6622 VCC = 3.3V ±2% Atmel ATA6624 VCC = 5.0V ±2% Atmel ATA6626 VCC = 5.0V ±2%, TXD time-out timer disabled In Sleep Mode VCC is switched off VCC- undervoltage detection (4ms reset time) and watchdog reset logical combined at open drain output NRES Negative trigger input for watchdog Boosting the voltage regulator possible with an external NPN transistor LIN physical layer according to LIN 2.0, 2.1 and SAEJ2602-2 Wake-up capability via LIN-bus, wake pin, or Kl_15 pin INH output to control an external voltage regulator or to switch off the master p
  • Вид монтажа: SMD/SMT
  • Высота: 0.85 мм
  • Диапазон напряжения питания: 5 В ...
    27 В
  • Длина: 5 мм
  • Рабочий диапазон температрур: - 40 C ... + 150 C
  • Серия процессора: ATA6x
  • Тип корпуса: QFN-20
  • Шина данных: 8 бит
  • Ширина: 5 мм
  • Ядро: AVR8
  • RoHS: да
ATA6622PGQW, ATA6622 PGQW
На английском языке: Datasheet ATA6622-PGQW - Atmel Microcontrollers (MCU) LIN Networking System Basis Chip
