Datasheet ATMEGA8U2-MUR - Atmel Даташит Микроконтроллеры (MCU) USB 8K FLASH 16 МГц — Даташит
Наименование модели: ATMEGA8U2-MUR
26 предложений от 17 поставщиков
IC MCU 8BIT 8KB FLASH 32VQFN. AVR AVR® ATmega Microcontroller IC 8-Bit 16MHz 8KB (4K x 16) FLASH 32-VQFN (5x5). Embedded...
ATMEGA8U2-MUR
71 ₽
ATMEGA8U2-MUR
Atmel
167 ₽
Xinhuo Future
ATMEGA8U2-MUR
221 ₽
Эиком
ATMEGA8U2-MUR
от 517 ₽
Производитель: Atmel
Описание: Микроконтроллеры (MCU) USB 8K FLASH 16 МГц
data sheetСкачать Data Sheet
Features
· High Performance, Low Power AVR® 8-Bit Microcontroller · Advanced RISC Architecture
­ 125 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 16 MIPS Throughput at 16 MHz · Non-volatile Program and Data Memories ­ 8K/16K/32K Bytes of In-System Self-Programmable Flash ­ 512/512/1024 EEPROM ­ 512/512/1024 Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/ 100,000 EEPROM ­ Data retention: 20 years at 85°C/ 100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by on-chip Boot Program hardware-activated after reset True Read-While-Write Operation ­ Programming Lock for Software Security · USB 2.0 Full-speed Device Module with Interrupt on Transfer Completion ­ Complies fully with Universal Serial Bus Specification REV 2.0 ­ 48 MHz PLL for Full-speed Bus Operation : data transfer rates at 12 Mbit/s ­ Fully independant 176 bytes USB DPRAM for endpoint memory
  • Шина данных: 8 бит
  • RoHS: да
ATMEGA8U2MUR, ATMEGA8U2 MUR
На английском языке: Datasheet ATMEGA8U2-MUR - Atmel Microcontrollers (MCU) USB 8K FLASH 16 MHz
