Datasheet ATAM862P-TNQY8D - Atmel Даташит Микроконтроллеры (MCU) micrium Transm — Даташит
Наименование модели: ATAM862P-TNQY8D
Купить ATAM862P-TNQY8D на РадиоЛоцман.Цены — от 569 до 759 ₽ 9 предложений от 9 поставщиков MCU 4Bit MARC4 CISC 4KB Flash 2.5V/3.3V 24Pin SSO T/R | |||
ATAM862P-TNQY8D Microchip | 569 ₽ | ||
ATAM862P-TNQY8D Atmel | 714 ₽ | ||
ATAM862P-TNQY8D Atmel | по запросу | ||
ATAM862P-TNQY8D Microchip | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) micrium Transm.
868/915 МГц FLASH
Features
Single Package Fully-integrated 4-bit Microcontroller with RF Transmitter Low Power Consumption in Sleep Mode (< 1 µA Typically) Flash Controller for Application Program Available Maximum Output Power with Low Supply Current 2.0V to 4.0V Operation Voltage for Single Li-cell Power Supply 40°C to +125°C Operation Temperature SSO24 Package About Seven External Components
1. Description
The ATAM862-8 is a single package dual-chip circuit. It combines a UHF ASK/FSK transmitter with a 4-bit microcontroller. It supports highly integrated solutions in car access and tire pressure monitoring applications, as well as manifold applications in the industrial and consumer segment. It is available for the transmitting frequency range of 868 MHz to 928 MHz with data rates up to 32 kbaud Manchester coded. For further frequency ranges 310 MHz to 330 MHz and 429 MHz to 439 MHz separate datasheets are available. The device contains a flash microcontroller. Figure 1-1. Applicati
- Вид монтажа: SMD/SMT
- Высота: 1.3 мм
- Длина: 8.05 мм
- Серия процессора: ATAM862x
- Тип корпуса: SSO-24
- Шина данных: 4 бит
- Ширина: 4.4 мм
- Ядро: MARC4
- RoHS: да
ATAM862PTNQY8D, ATAM862P TNQY8D
