Datasheet AT32UC3C2512C-A2ZT - Atmel Даташит Микроконтроллеры (MCU) 512 Кб FL, -40/125oC AUTO — Даташит
Наименование модели: AT32UC3C2512C-A2ZT
Купить AT32UC3C2512C-A2ZT на РадиоЛоцман.Цены — от 591 до 754 ₽13 предложений от 13 поставщиков IC MCU 32BIT 512KB FLASH 64TQFP. AVR Automotive, AEC-Q100, AVR®32 UC3 C Microcontroller IC 32-Bit 66MHz 512KB (512K x 8) FLASH... | |||
| AT32UC3C2512C-A2ZT Microchip | по запросу | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 512 Кб FL, -40/125oC AUTO
Features
· High Performance, Low Power 32-bit AVR® Microcontroller
Compact Single-cycle RISC Instruction Set Including DSP Instruction Set Built-in Floating-Point Processing Unit (FPU) Read-Modify-Write Instructions and Atomic Bit Manipulation Performing 1.49 DMIPS / MHz · Up to 68 DMIPS Running at 50 MHz from Flash (1 Wait-State) · Up to 37 DMIPS Running at 25 MHz from Flash (0 Wait-State) Memory Protection Unit Multi-hierarchy Bus System High-Performance Data Transfers on Separate Buses for Increased Performance 16 Peripheral DMA Channels Improves Speed for Peripheral Communication Internal High-Speed Flash 512 Kbytes, 256 Kbytes, 128 Kbytes, 64 Kbytes Versions Single Cycle Access up to 25 MHz FlashVaultTM Technology Allows Pre-programmed Secure Library Support for End User Applications Prefetch Buffer Optimizing Instruction Execution at Maximum Speed 10,000 Write Cycles, 15-year Data Retention Capability Flash Security Locks and User Defined Configuration Area Inte
- Упаковка: Tray
- RoHS: да
AT32UC3C2512CA2ZT, AT32UC3C2512C A2ZT
