Datasheet AT32UC3C0512C-ALZR - Atmel Даташит Микроконтроллеры (MCU) 512 Кб FL, -40/125oC AUTO — Даташит
Наименование модели: AT32UC3C0512C-ALZR
IC MCU 32BIT 512KB FLASH 144LQFP. AVR Automotive, AEC-Q100, AVR®32 UC3 C Microcontroller IC 32-Bit 50MHz 512KB (512K x 8) FLASH...
AT32UC3C0512C-ALZR
754 ₽
Рутоника
AT32UC3C0512C-ALZR
761 ₽
Hi-Tech Circuit Group
AT32UC3C0512C-ALZR
AT32UC3C0512C-ALZR
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 512 Кб FL, -40/125oC AUTO
data sheetСкачать Data Sheet
Features
· High Performance, Low Power 32-bit AVR® Microcontroller
Compact Single-cycle RISC Instruction Set Including DSP Instruction Set Built-in Floating-Point Processing Unit (FPU) Read-Modify-Write Instructions and Atomic Bit Manipulation Performing 1.49 DMIPS / MHz · Up to 68 DMIPS Running at 50 MHz from Flash (1 Wait-State) · Up to 37 DMIPS Running at 25 MHz from Flash (0 Wait-State) ­ Memory Protection Unit Multi-hierarchy Bus System ­ High-Performance Data Transfers on Separate Buses for Increased Performance ­ 16 Peripheral DMA Channels Improves Speed for Peripheral Communication Internal High-Speed Flash ­ 512 Kbytes, 256 Kbytes, 128 Kbytes, 64 Kbytes Versions ­ Single Cycle Access up to 25 MHz ­ FlashVaultTM Technology Allows Pre-programmed Secure Library Support for End User Applications ­ Prefetch Buffer Optimizing Instruction Execution at Maximum Speed ­ 10,000 Write Cycles, 15-year Data Retention Capability ­ Flash Security Locks and User Defined Configuration Area Inte
  • Упаковка: Reel
  • RoHS: да
AT32UC3C0512CALZR, AT32UC3C0512C ALZR
На английском языке: Datasheet AT32UC3C0512C-ALZR - Atmel Microcontrollers (MCU) 512 Kb FL, -40/125oC AUTO
