Datasheet AT32UC3C2256C-A2UR - Atmel Даташит Микроконтроллеры (MCU) UC3C 256K FLASH 64K SRAM — Даташит
Наименование модели: AT32UC3C2256C-A2UR
![]() 24 предложений от 13 поставщиков Микросхема Микроконтроллер, MCU 32Bit AT32 AVR RISC 256KB Flash 3.3V/5V 64Pin TQFP T/R | |||
AT32UC3C2256C-A2UR Atmel | 80 ₽ | ||
AT32UC3C2256C-A2UR Atmel | по запросу | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) UC3C 256K FLASH 64K SRAM
Features
· High Performance, Low Power 32-bit AVR® Microcontroller
Compact Single-cycle RISC Instruction Set Including DSP Instruction Set Built-in Floating-Point Processing Unit (FPU) Read-Modify-Write Instructions and Atomic Bit Manipulation Performing 1.49 DMIPS / MHz · Up to 91 DMIPS Running at 66 MHz from Flash (1 Wait-State) · Up to 49 DMIPS Running at 33 MHz from Flash (0 Wait-State) Memory Protection Unit Multi-hierarchy Bus System High-Performance Data Transfers on Separate Buses for Increased Performance 16 Peripheral DMA Channels Improves Speed for Peripheral Communication Internal High-Speed Flash 512 Kbytes, 256 Kbytes, 128 Kbytes, 64 Kbytes Versions Single Cycle Access up to 33 MHz FlashVaultTM Technology Allows Pre-programmed Secure Library Support for End User Applications Prefetch Buffer Optimizing Instruction Execution at Maximum Speed 100,000 Write Cycles, 15-year Data Retention Capability Flash Security Locks and User Defined Configuration Area Int
- Упаковка: Reel
- Шина данных: 32 бит
- RoHS: да
AT32UC3C2256CA2UR, AT32UC3C2256C A2UR
