Datasheet Microchip PIC32MX340F128LT-80I/PT — Даташит
СерияPIC32MX340F128L
МодельPIC32MX340F128LT-80I/PT
PIC32MX3XX/4XX Family Data Sheet
PDF, 4.2 Мб, Версия: 05-09-2011
IC MCU 32BIT 128KB FLASH 100TQFP. MIPS32® M4KTM PIC® 32MX Microcontroller IC 32-Bit 80MHz 128KB (128K x 8) FLASH 100-TQFP...
482 ₽
Hi-Tech Circuit Group
КорпусTQFP
Количество выводов100
# of Comparators2
ADCC with ComputationNo
Angular TimerNo
Архитектура32
CPU32-bit MIPS MCU
CRC/ScanYes
Cap. Touch Channels16
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C2
Math AcceleratorNo
Max # PWM outputs5 including complementary outputs
Max 16 Bit Digital Timers5
Max A/D Resolution10 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz80
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)2.3
Peripheral Pin SelectNo PPS
Pin count100
Размер памяти программ128 Kbytes
RAM32768 bytes
SPIв„ў2
Temp. Range Max.105
Temp. Range Min.-40
Total # of A/D channels16
UART2
Zero Cross detectNo
PIC32MX320F032H PIC32MX320F064H PIC32MX320F128H PIC32MX320F128L PIC32MX340F128H PIC32MX340F256H PIC32MX340F512H PIC32MX360F256L PIC32MX360F512L PIC32MX420F032H PIC32MX440F128H PIC32MX440F128L PIC32MX440F256H PIC32MX440F512H PIC32MX460F256L PIC32MX460F512L
PIC32MX340F128LT80I/PT, PIC32MX340F128LT 80I/PT
На английском языке: Datasheet Microchip PIC32MX340F128LT-80I/PT
