Datasheet ATMEGA32A-MN - Atmel Даташит Микроконтроллеры (MCU) AVR 32 Кб FL 1 Кб EE 2 Кб SRAM 16 МГц Grn — Даташит
Наименование модели: ATMEGA32A-MN
![]() 9 предложений от 9 поставщиков Микросхема Микроконтроллер, MCU 8Bit ATmega AVR RISC 32KB Flash 3.3V/5V 44Pin QFN EP | |||
ATMEGA32A-MN Atmel | 80 ₽ | ||
ATMEGA32A-MN Atmel | по запросу | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 32 Кб FL 1 Кб EE 2 Кб SRAM 16 МГц Grn
Features
· High-performance, Low-power Atmel® AVR® 8-bit Microcontroller · Advanced RISC Architecture
131 Powerful Instructions Most Single-clock Cycle Execution 32 x 8 General Purpose Working Registers Fully Static Operation Up to 16 MIPS Throughput at 16 MHz On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments 32 Kbytes of In-System Self-programmable Flash program memory 1024 Bytes EEPROM 2 Kbyte Internal SRAM Write/Erase Cycles: 10,000 Flash/100,000 EEPROM Data retention: 20 years at 85°C/100 years at 25°C(1) Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation Programming Lock for Software Security JTAG (IEEE std.
1149.1 Compliant) Interface Boundary-scan Capabilities According to the JTAG Standard Extensive On-chip Debug Support Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface Peripheral Features Two 8-bit Timer/Counters wi
- Шина данных: 8 бит Factory Pack Quantity:416
- Ядро: AVR
- RoHS: да
ATMEGA32AMN, ATMEGA32A MN
