Datasheet ATAM862P-TNSY4D - Atmel Даташит Микроконтроллеры (MCU) micrium Transm — Даташит
Наименование модели: ATAM862P-TNSY4D
![]() 9 предложений от 9 поставщиков Микросхема Микроконтроллер, IC MCU FLASH 4K TX 433MHz 24SSOP | |||
ATAM862P-TNSY4D Microchip | 499 ₽ | ||
ATAM862P-TNSY4D Microchip | 558 ₽ | ||
ATAM862P-TNSY4D Microchip | 568 ₽ | ||
ATAM862P-TNSY4D Microchip | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) micrium Transm.
433 МГц FLASH 125 C
Features
Single Package Fully-integrated 4-bit Flash Microcontroller with RF Transmitter Low Power Consumption in Sleep Mode (< 1 µA Typically) Maximum Output Power with Low Supply Current 2.0V to 4.0V Operation Voltage for Single Li-cell Power Supply 40°C to +125°C Operation Temperature SSO24 Package About Seven External Components
1. Description
The ATAM862-4 is a single package dual-chip circuit. It combines a UHF ASK/FSK transmitter with a 4-bit microcontroller. It supports highly integrated solutions in car access and tire pressure monitoring applications, as well as manifold applications in the industrial and consumer segment. It is available for the transmitting frequency range of 429 MHz to 439 MHz with data rates up to 32 kbaud Manchester coded. For further frequency ranges such as 310 MHz to 330 MHz and 868 MHz to 928 MHz separate datasheets are available. The device contains a flash microcontroller. Figure 1-1. Application Diagram
- Вид монтажа: SMD/SMT
- Высота: 1.3 мм
- Длина: 8.05 мм
- Серия процессора: ATAM862x
- Тип корпуса: SSO-24
- Шина данных: 4 бит
- Ширина: 4.5 мм
- Ядро: MARC4
- RoHS: да
ATAM862PTNSY4D, ATAM862P TNSY4D
