Datasheet ATUC128D3-A2UR - Atmel Даташит Микроконтроллеры (MCU) UC3D3 128 Кб FL 85C — Даташит
Наименование модели: ATUC128D3-A2UR
IC MCU 32BIT 128KB FLASH 64LQFP. AVR AVR®32 UC3 D Microcontroller IC 32-Bit 48MHz 128KB (128K x 8) FLASH 64-LQFP (10x10)....
ATUC128D3-A2UR
301 ₽
ATUC128D3-A2UR
393 ₽
ATUC128D3-A2UR
ATUC128D3-A2UR
Производитель: Atmel
Описание: Микроконтроллеры (MCU) UC3D3 128 Кб FL 85C
data sheetСкачать Data Sheet
Features
· High Performance, Low Power 32-bit AVR® Microcontroller
­ Compact Single-Cycle RISC Instruction Set Including DSP Instructions ­ Read-Modify-Write Instructions and Atomic Bit Manipulation ­ Performance · Up to 61 DMIPS Running at 48MHz from Flash (1 Flash Wait State) · Up to 34 DMIPS Running at 24MHz from Flash (0 Flash Wait State) Multi-Hierarchy Bus System ­ High-Performance Data Transfers on Separate Buses for Increased Performance ­ 7 Peripheral DMA Channels Improve Speed for Peripheral Communication Internal High-Speed Flash ­ 128Kbytes, and 64Kbytes Versions ­ Single-Cycle Access up to 24MHz ­ Prefetch Buffer Optimizing Instruction Execution at Maximum Speed ­ 4ms Page Programming Time and 8ms Full-Chip Erase Time ­ 100,000 Write Cycles, 15-year Data Retention Capability ­ Flash Security Locks and User Defined Configuration Area Internal High-Speed SRAM, Single-Cycle Access at Full Speed ­ 16Kbytes Interrupt Controller (INTC) ­ Autovectored Low Latency Interrupt Servic
  • Серия процессора: ATUC
  • Упаковка: Reel
  • Шина данных: 32 бит
  • Ядро: AVR
  • RoHS: да
ATUC128D3A2UR, ATUC128D3 A2UR
На английском языке: Datasheet ATUC128D3-A2UR - Atmel Microcontrollers (MCU) UC3D3 128 Kb FL 85C
