Datasheet AD5750-2BCPZ - Analog Devices Даташит INDUSTRIAL PROG O/P I, В DRVR, 32LFCSP — Даташит
Analog Devices AD5750-2BCPZ
Наименование модели: AD5750-2BCPZ
27 предложений от 16 поставщиков
AD5750-2BCPZ
268 ₽
AD5750-2BCPZ-RL7
392 ₽
Элитан
AD5750-2BCPZ
988 ₽
ТаймЧипс
AD5750-2BCPZ
Производитель: Analog Devices
Описание: INDUSTRIAL PROG O/P I, В DRVR, 32LFCSP
data sheetСкачать Data Sheet
Data Sheet
FEATURES
Industrial Current/Voltage Output Driver with Programmable Ranges AD5750/AD5750-1/AD5750-2
The output current range is programmable across five current ranges: 4 mA to 20 mA, 0 mA to 20 mA, 0 mA to 24 mA, ±20 mA, and ±24 mA.
An overrange of 2% is available on the unipolar current ranges. Voltage output is provided from a separate pin that can be configured to provide 0 V to 5 V, 0 V to 10 V, ±5 V, or ±10 V output ranges. An overrange of 20% is available on the voltage ranges. Analog outputs are short-circuit and open-circuit protected and can drive capacitive loads of 1 µF and inductive loads of 0.1 H. The devices are specified to operate with a power supply range from ±12 V to ±24 V. Output loop compliance is 0 V to AVDD - 2.75 V. The flexible serial interface is SPI and MICROWIRE compatible and can operate in 3-wire mode to minimize the digital isolation required in isolated applications. The interface also features an optional PEC feature using CRC-8 error check
  • Влагостойкость: MSL 3 - 168 hours
  • Диапазон напряжения питания: 12 В ... 24 В
  • Количество выводов: 32
  • Количество усилителей: 2
  • Рабочий диапазон температрур: -40°C ... +105°C
  • Скорость нарастания: 2 В/мкс
  • Тип корпуса: LFCSP
  • Ток потребления: 4.4 мА
  • RoHS: да
  • SVHC: No SVHC (19-Dec-2011)
AD57502BCPZ, AD5750 2BCPZ
На английском языке: Datasheet AD5750-2BCPZ - Analog Devices INDUSTRIAL PROG O/P I, V DRVR, 32LFCSP
