Datasheet MAX931CSA+ - Maxim Даташит Компаратор, 11VIN, 1.182VREF, 8SOIC — Даташит
Наименование модели: MAX931CSA+
Купить MAX931CSA+ на РадиоЛоцман.Цены — от 53 до 1 067 ₽51 предложений от 25 поставщиков Аналоговый компаратор, Micropower, 1 Компаратор, 12 мкс, 2.5В до 11В, ± 1.25В до ± 5.5В, SOIC | |||
| MAX931CSA Maxim | 81 ₽ | ||
| Микросхема MAX931CSA Maxim | 235 ₽ | ||
| MAX931CSA+ Maxim | от 292 ₽ | ||
| MAX931CSA+T Maxim | по запросу | ||
Производитель: Maxim
Описание: Компаратор, 11VIN, 1.182VREF, 8SOIC
19-0194; Rev 1; 2/97
Ultra Low-Power, Low-Cost Comparators with 2% Reference
_______________General Description
The MAX931-MAX934 single, dual, and quad micropower, low-voltage comparators plus an on-board 2% accurate reference feature the lowest power consumption available.
These comparators draw less than 4µA supply current over temperature (MAX931), and include an internal 1.182V ±2% voltage reference, programmable hysteresis, and TTL/CMOS outputs that sink and source current. Ideal for 3V or 5V single-supply applications, the MAX931-MAX934 operate from a single +2.5V to +11V supply (or a ±1.25V to ±5V dual supply), and each comparator's input voltage range extends from the negative supply rail to within 1.3V of the positive supply. The MAX931-MAX934's unique output stage continuously sources as much as 40mA. And by eliminating powersupply glitches that commonly occur when comparators change logic states, the MAX931-MAX934 minimize parasitic feedback, which makes them easier to use
- Output Compatibility: CMOS, TTL
- Влагостойкость: MSL 1 - Unlimited
- Время отклика: 12 мкс
- Диапазон напряжения питания: 2.5 В ... 11 В, ± 1.25 В ... ± 5.5 В
- Количество выводов: 8
- Количество компараторов: 1
- Рабочий диапазон температрур: 0°C ... +70°C
- Тип компаратора: Low Voltage
- Тип корпуса: SOIC
- Ток потребления: 2.5 мкА
- RoHS: да
