Datasheet LM3812M-7.0/NOPB - National Semiconductor Даташит ИС, ШИМ контроллер — Даташит
Наименование модели: LM3812M-7.0/NOPB
10 предложений от 10 поставщиков IC CURRENT GAUGE PREC 8-SOIC. Current Gauge Regulator High-Side 8-SOIC. PMIC - Current Regulation/Management | |||
| LM3812M-7.0/NOPB Texas Instruments | 65 ₽ | ||
| LM3812M-7.0/NOPB Texas Instruments | по запросу | ||
Описание: ИС, ШИМ контроллер
LM3812/LM3813 Precision Current Gauge IC with Ultra Low Loss Sense Element and PWM Output
February 2005
General Description
The LM3812/LM3813 Current Gauges provide easy to use precision current measurement with virtually zero insertion loss (typically 0.004).
The LM3812 is used for high-side sensing and the LM3813 is used for low-side sensing. A Delta Sigma analog to digital converter is incorporated to precisely measure the current and to provide a current averaging function. Current is averaged over 50 msec time periods in order to provide immunity to current spikes. The ICs have a pulse-width modulated (PWM) output which indicates the current magnitude and direction. The shutdown pin can be used to inhibit false triggering during start-up, or to enter a low quiescent current mode. The LM3812 and LM3813 are factory-set in two different current options. The sense range is -1A to +1A or -7A to
- Входное напряжение максимальное: 5.25 В
- Входное напряжение: 5 В
- Выходной ток: 1 мА
- Диапазон напряжения питания: 2 В ... 5.25 В
- Интерфейс: Serial, SPI
- Количество выводов: 8
- Рабочий диапазон температрур: -40°C ... +125°C
- Семейство: 3812
- Способ монтажа: SMD
- Тип корпуса: SOIC
- RoHS: да
- SVHC: No SVHC (19-Dec-2011)
LM3812M7.0/NOPB, LM3812M 7.0/NOPB
Купить LM3812M-7.0/NOPB на РадиоЛоцман.Цены
