Datasheet Texas Instruments TPA2080D1YZGT — Даташит
СерияTPA2080D1
МодельTPA2080D1YZGT
Аудиоусилитель класса D постоянной выходной мощностью 2,2 Вт с повышающим преобразователем класса G 12-DSBGA от -40 до 85
TPA2080D1 2.2-W Constant Output Power Class-D Audio Amplifier With Class-G Boost Converter datasheet
PDF, 1.6 Мб, Версия: B, Файл опубликован: 27 апр 2016
Pin12
Package TypeYZG
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаTPA2080D1
Thickness (мм).375
Pitch (мм).5
Max Height (мм).625
Analog Supply (V)5.2 Min
АрхитектураClass D
Audio Input TypeAnalog Input
Control InterfaceGPIO
Iq per channel(Typ)2 мА
Iq(Max)6 мА
Iq(Typ)2 мА
Load(Min)4 ohms
Выходная мощность2.2 W
PSRR62.5 дБ
Package GroupDSBGA
Pin/Package12DSBGA
Shutdown Current (ISD)0.2 uA
Speaker ChannelsMono Max
THD + N @ 1 kHz0.07 %
  • Evaluation Modules & Boards: TPA2080D1YZGEVM
    TPA2080D1 Evalution Module
  • Filter-Free Class-D Audio Amplifiers
    PDF, 259 Кб, Файл опубликован: 9 ноя 2009
    Traditional Class-D amplifiers lose efficiency if they do not use output LC filters. Texas Instruments offers many Class-D amplifiers that are designated Filter-Free. This means they do not require an output LC filter to maintain high efficiency. However, in some cases an LC or ferrite bead filter is required for EMC.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA2080D1 (2)
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA2080D1YZGT
