Datasheet ATMEGA168A-CCU - Atmel Даташит Микроконтроллеры (MCU) AVR 16 Кб FL 512B EE 1 Кб SRAM-20MHz — Даташит
Наименование модели: ATMEGA168A-CCU
IC MCU 8BIT 16KB FLASH 32UFBGA. AVR AVR® ATmega Microcontroller IC 8-Bit 20MHz 16KB (8K x 16) FLASH 32-UFBGA (4x4). Embedded...
ATMEGA168A-CCU
Atmel
79 ₽
ATMEGA168A-CCU
Atmel
79 ₽
Hi-Tech Circuit Group
ATMEGA168A-CCU
МосЧип
ATMEGA168A-CCU
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 16 Кб FL 512B EE 1 Кб SRAM-20MHz
data sheetСкачать Data Sheet
Features
· High Performance, Low Power Atmel®AVR® 8-Bit Microcontroller · Advanced RISC Architecture
­ 131 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 20 MIPS Throughput at 20MHz ­ On-chip 2-cycle Multiplier High Endurance Non-volatile Memory Segments ­ 4/8/16/32KBytes of In-System Self-Programmable Flash program memory ­ 256/512/512/1KBytes EEPROM ­ 512/1K/1K/2KBytes Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ Programming Lock for Software Security Atmel® QTouch® library support ­ Capacitive touch buttons, sliders and wheels ­ QTouch and QMatrix® acquisition ­ Up to 64 sense channels Peripheral Features ­ Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode ­ One 16-bit Timer
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA168ACCU, ATMEGA168A CCU
На английском языке: Datasheet ATMEGA168A-CCU - Atmel Microcontrollers (MCU) AVR 16 Kb FL 512B EE 1 Kb SRAM-20MHz
