Datasheet ATMEGA16A-MUR - Atmel Даташит Микроконтроллеры (MCU) AVR 16 Кб FLASH 512B EE 1 Кб SRAM-16MHZ — Даташит
Наименование модели: ATMEGA16A-MUR
31 предложений от 17 поставщиков
IC MCU 8BIT 16KB FLASH 44VQFN. AVR AVR® ATmega Microcontroller IC 8-Bit 16MHz 16KB (8K x 16) FLASH 44-VQFN (7x7). Embedded...
ATMEGA16A-MUR
от 84 ₽
ATMEGA16A-MUR
Atmel
201 ₽
ATMEGA16A-MUR
Atmel
201 ₽
Эиком
ATMEGA16A-MUR
от 614 ₽
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 16 Кб FLASH 512B EE 1 Кб SRAM-16MHZ
data sheetСкачать Data Sheet
Features
· High-performance, Low-power AVR® 8-bit Microcontroller · Advanced RISC Architecture
­ 131 Powerful Instructions ­ Most Single-clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 16 MIPS Throughput at 16 MHz ­ On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments ­ 16K Bytes of In-System Self-programmable Flash program memory ­ 512 Bytes EEPROM ­ 1K Byte Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits · In-System Programming by On-chip Boot Program · True Read-While-Write Operation ­ Programming Lock for Software Security JTAG (IEEE std.
1149.1 Compliant) Interface ­ Boundary-scan Capabilities According to the JTAG Standard ­ Extensive On-chip Debug Support ­ Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface Peripheral Features ­ Two 8-bit Timer/Counters with S
  • Упаковка: Reel
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA16AMUR, ATMEGA16A MUR
На английском языке: Datasheet ATMEGA16A-MUR - Atmel Microcontrollers (MCU) AVR 16 Kb FLASH 512B EE 1 Kb SRAM-16MHZ
