Datasheet ATMEGA168PA-MUR - Atmel Даташит Микроконтроллеры (MCU) AVR 16 Кб FL 512B EE 1 Кб SRAM-20MHZ 5 В — Даташит
Наименование модели: ATMEGA168PA-MUR
23 предложений от 17 поставщиков
IC MCU 8BIT 16KB FLASH 32VQFN. AVR AVR® ATmega Microcontroller IC 8-Bit 20MHz 16KB (8K x 16) FLASH 32-VQFN (5x5). Embedded...
ATMEGA168PA-MUR
Atmel
79 ₽
ATMEGA168PA-MUR
91 ₽
ATMEGA168PA-MUR
189 ₽
Зенер
Россия и страны ТС
ATMEGA168PA-MUR
от 305 ₽
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 16 Кб FL 512B EE 1 Кб SRAM-20MHZ 5 В
data sheetСкачать Data Sheet
Features
· High Performance, Low Power AVR® 8-Bit Microcontroller · Advanced RISC Architecture
­ 131 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 20 MIPS Throughput at 20 MHz ­ On-chip 2-cycle Multiplier High Endurance Non-volatile Memory Segments ­ 4/8/16/32K Bytes of In-System Self-Programmable Flash program memory ­ 256/512/512/1K Bytes EEPROM ­ 512/1K/1K/2K Bytes Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ Programming Lock for Software Security Peripheral Features ­ Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode ­ One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode ­ Real Time Counter with Separate Oscillator ­ Six PWM Channels ­ 8-channel
  • Упаковка: Reel
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA168PAMUR, ATMEGA168PA MUR
На английском языке: Datasheet ATMEGA168PA-MUR - Atmel Microcontrollers (MCU) AVR 16 Kb FL 512B EE 1 Kb SRAM-20MHZ 5 V
