Линейка продуктов KEEN SIDE
Datasheet ATMEGA32M1-AUR - Atmel Даташит Микроконтроллеры (MCU) 16 МГц, IND TEMP — Даташит
Наименование модели: ATMEGA32M1-AUR
22 предложений от 12 поставщиков
Микросхема Микроконтроллер, 16MHz, TQFP, IND TEMP, GREEN, T&R
ATMEGA32M1-AUR
489 ₽
727GS
ATMEGA32M1-AUR
от 645 ₽
ATMEGA32M1-AUR
Atmel
ATMEGA32M1-AUR
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 16 МГц, IND TEMP
data sheetСкачать Data Sheet
Features
· High Performance, Low Power Atmel®AVR® 8-bit Microcontroller · Advanced RISC Architecture
­ 131 Powerful Instructions - Most Single Clock Cycle Execution ­ 32 Ч 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 1 MIPS throughput per MHz ­ On-chip 2-cycle Multiplier Data and Non-Volatile Program Memory ­ 16/32/64K Bytes Flash of In-System Programmable Program Memory ­ 512B/1K/2K Bytes of In-System Programmable EEPROM ­ 1/2/4K Bytes Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/ 100,000 EEPROM ­ Data Retention: 20 years at 85°C/ 100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ Programming Lock for Flash Program and EEPROM Data Security On Chip Debug Interface (debugWIRE) CAN 2.0A/B with 6 Message Objects - ISO 16845 Certified LIN 2.1 and 1.3 Controller or 8-Bit UART One 12-bit High Speed PSC (Power Stage Controller) ­ Non Overlapping Inverted PWM Ou
  • Упаковка: Reel
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA32M1AUR, ATMEGA32M1 AUR
На английском языке: Datasheet ATMEGA32M1-AUR - Atmel Microcontrollers (MCU) 16 MHz, IND TEMP
