Datasheet AT32UC3C1512C-AZR - Atmel Даташит Микроконтроллеры (MCU) 512 Кб FL, -40/125oC AUTO — Даташит
Наименование модели: AT32UC3C1512C-AZR
![]() 15 предложений от 12 поставщиков Микросхема Микроконтроллер, MCU 32Bit AT32 AVR RISC 512KB Flash 3.3V/5V 100Pin TQFP T/R | |||
AT32UC3C1512C-AZR Microchip | 635 ₽ | ||
AT32UC3C1512C-AZR Atmel | 785 ₽ | ||
AT32UC3C1512C-AZR Microchip | 828 ₽ | ||
AT32UC3C1512C-AZR Atmel | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 512 Кб FL, -40/125oC AUTO
Features
· High Performance, Low Power 32-bit AVR® Microcontroller
Compact Single-cycle RISC Instruction Set Including DSP Instruction Set Built-in Floating-Point Processing Unit (FPU) Read-Modify-Write Instructions and Atomic Bit Manipulation Performing 1.49 DMIPS / MHz · Up to 68 DMIPS Running at 50 MHz from Flash (1 Wait-State) · Up to 37 DMIPS Running at 25 MHz from Flash (0 Wait-State) Memory Protection Unit Multi-hierarchy Bus System High-Performance Data Transfers on Separate Buses for Increased Performance 16 Peripheral DMA Channels Improves Speed for Peripheral Communication Internal High-Speed Flash 512 Kbytes, 256 Kbytes, 128 Kbytes, 64 Kbytes Versions Single Cycle Access up to 25 MHz FlashVaultTM Technology Allows Pre-programmed Secure Library Support for End User Applications Prefetch Buffer Optimizing Instruction Execution at Maximum Speed 10,000 Write Cycles, 15-year Data Retention Capability Flash Security Locks and User Defined Configuration Area Inte
- Упаковка: Reel
- Шина данных: 32 бит
- RoHS: да
AT32UC3C1512CAZR, AT32UC3C1512C AZR
