Datasheet ATMEGA16A-AUR - Atmel Даташит Микроконтроллеры (MCU) AVR жки 16 Кб FLSH EE 512B 1 Кб SRAM-16MHZ — Даташит
Наименование модели: ATMEGA16A-AUR
Купить ATMEGA16A-AUR на РадиоЛоцман.Цены — от 81 до 619 ₽30 предложений от 18 поставщиков IC MCU 8BIT 16KB FLASH 44TQFP. AVR AVR® ATmega Microcontroller IC 8-Bit 16MHz 16KB (8K x 16) FLASH 44-TQFP (10x10). Embedded... | |||
| ATMEGA16A-AUR Atmel | 81 ₽ | ||
| ATMEGA16A-AUR Microchip | 81 ₽ | ||
| ATMEGA16A-AUR Microchip | от 557 ₽ | ||
| ATMEGA16A-AUR Microchip | от 588 ₽ | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR жки 16 Кб FLSH EE 512B 1 Кб SRAM-16MHZ
Features
· High-performance, Low-power AVR® 8-bit Microcontroller · Advanced RISC Architecture
131 Powerful Instructions Most Single-clock Cycle Execution 32 x 8 General Purpose Working Registers Fully Static Operation Up to 16 MIPS Throughput at 16 MHz On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments 16K Bytes of In-System Self-programmable Flash program memory 512 Bytes EEPROM 1K Byte Internal SRAM Write/Erase Cycles: 10,000 Flash/100,000 EEPROM Data retention: 20 years at 85°C/100 years at 25°C(1) Optional Boot Code Section with Independent Lock Bits · In-System Programming by On-chip Boot Program · True Read-While-Write Operation Programming Lock for Software Security JTAG (IEEE std.
1149.1 Compliant) Interface Boundary-scan Capabilities According to the JTAG Standard Extensive On-chip Debug Support Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface Peripheral Features Two 8-bit Timer/Counters with S
- Упаковка: Reel
- Шина данных: 8 бит
- Ядро: AVR
- RoHS: да
ATMEGA16AAUR, ATMEGA16A AUR
