Datasheet Texas Instruments LM3S5P3B-IBZ80-C5 — Даташит
СерияLM3S5P3B
МодельLM3S5P3B-IBZ80-C5
Микроконтроллер Stellaris LM3S 108-NFBGA от -40 до 85
Stellaris LM3S5P3B Microcontroller Data Sheet datasheet
PDF, 6.7 Мб, Версия: C, Файл опубликован: 3 июл 2014
Pin108108
Package TypeZCRZCR
Industry STD TermNFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-N
МаркировкаLM3S5P3BIBZ80
Width (мм)1010
Length (мм)1010
Thickness (мм).95.95
Pitch (мм).8.8
Max Height (мм)1.51.5
RoHSНе совместим
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
  • USB Certification for Stellaris-Based USB Peripherals and Embedded Host Systems
    PDF, 3.9 Мб, Файл опубликован: 7 июл 2009
    This application note describes the USB-IF certification process for a USB full-speed device and a USB full-speed embedded host system using the a Stellaris LM3S5732 microcontroller as the example.
LM3S5P3BIBZ80C5, LM3S5P3B IBZ80 C5
На английском языке: Datasheet Texas Instruments LM3S5P3B-IBZ80-C5
