Datasheet ATMEGA32A-AUR - Atmel Даташит Микроконтроллеры (MCU) AVR 32 Кб FLSH 1 Кб EE 2 Кб SRAM-16MHZ — Даташит
Наименование модели: ATMEGA32A-AUR
31 предложений от 18 поставщиков
ATMEGA32A-AUR
Atmel
83 ₽
ATMEGA32A-AUR
от 710 ₽
ATMEGA32A-AUR
Atmel
ТаймЧипс
ATMEGA32A-AUR
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 32 Кб FLSH 1 Кб EE 2 Кб SRAM-16MHZ
data sheetСкачать Data Sheet
Features
· High-performance, Low-power AVR® 8-bit Microcontroller · Advanced RISC Architecture
­ 131 Powerful Instructions ­ Most Single-clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 16 MIPS Throughput at 16 MHz ­ On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments ­ 32K Bytes of In-System Self-programmable Flash program memory ­ 1024 Bytes EEPROM ­ 2K Byte Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits · In-System Programming by On-chip Boot Program · True Read-While-Write Operation ­ Programming Lock for Software Security JTAG (IEEE std.
1149.1 Compliant) Interface ­ Boundary-scan Capabilities According to the JTAG Standard ­ Extensive On-chip Debug Support ­ Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface Peripheral Features ­ Two 8-bit Timer/Counters with
  • Упаковка: Reel
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA32AAUR, ATMEGA32A AUR
На английском языке: Datasheet ATMEGA32A-AUR - Atmel Microcontrollers (MCU) AVR 32 Kb FLSH 1 Kb EE 2 Kb SRAM-16MHZ
