Datasheet ATMEGA8515-16JUR - Atmel Даташит Микроконтроллеры (MCU) AVR 8 Кб FLSH 512B EE 512B SRAM-16MHz, IND — Даташит
Наименование модели: ATMEGA8515-16JUR
25 предложений от 14 поставщиков
Микросхема Микроконтроллер, AVR, 8KB FLASH, 512B EE, 512B SRAM - 16MHz, PLCC, IND TEMP, GREEN, T&R
ATMEGA8515-16JUR
150 ₽
ATMEGA8515-16JUR
Atmel
233 ₽
ATMEGA8515-16JUR
Atmel
290 ₽
Эиком
ATMEGA8515-16JUR
от 625 ₽
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 8 Кб FLSH 512B EE 512B SRAM-16MHz, IND
data sheetСкачать Data Sheet
Features
· High-performance, Low-power AVR® 8-bit Microcontroller · RISC Architecture
­ 130 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 16 MIPS Throughput at 16 MHz ­ On-chip 2-cycle Multiplier Nonvolatile Program and Data Memories ­ 8K Bytes of In-System Self-programmable Flash Endurance: 10,000 Write/Erase Cycles ­ Optional Boot Code Section with Independent Lock bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ 512 Bytes EEPROM Endurance: 100,000 Write/Erase Cycles ­ 512 Bytes Internal SRAM ­ Up to 64K Bytes Optional External Memory Space ­ Programming Lock for Software Security Peripheral Features ­ One 8-bit Timer/Counter with Separate Prescaler and Compare Mode ­ One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode ­ Three PWM Channels ­ Programmable Serial USART ­ Master/Slave SPI Serial Interface ­ Programmable Watchdog Timer w
  • Упаковка: Reel
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA851516JUR, ATMEGA8515 16JUR
На английском языке: Datasheet ATMEGA8515-16JUR - Atmel Microcontrollers (MCU) AVR 8 Kb FLSH 512B EE 512B SRAM-16MHz, IND
