Datasheet ATMEGA48PA-CCUR - Atmel Даташит Микроконтроллеры (MCU) AVR 4 Кб FLSH 256B EE 512B SRAM-20MHz IND — Даташит
Наименование модели: ATMEGA48PA-CCUR
Микросхема Микроконтроллер, MCU 8Bit ATmega AVR RISC 4KB Flash 2.5V/3.3V/5V 32Pin UFBGA T/R
ATMEGA48PA-CCUR
91 ₽
ATMEGA48PA-CCUR
Atmel
119 ₽
IC Home
ATMEGA48PA-CCUR
130 ₽
ATMEGA48PA-CCUR
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 4 Кб FLSH 256B EE 512B SRAM-20MHz IND
data sheetСкачать Data Sheet
Features
· High Performance, Low Power Atmel®AVR® 8-Bit Microcontroller · Advanced RISC Architecture
­ 131 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 20 MIPS Throughput at 20MHz ­ On-chip 2-cycle Multiplier High Endurance Non-volatile Memory Segments ­ 4/8/16/32KBytes of In-System Self-Programmable Flash program memory ­ 256/512/512/1KBytes EEPROM ­ 512/1K/1K/2KBytes Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ Programming Lock for Software Security Atmel® QTouch® library support ­ Capacitive touch buttons, sliders and wheels ­ QTouch and QMatrix® acquisition ­ Up to 64 sense channels Peripheral Features ­ Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode ­ One 16-bit Timer
  • Упаковка: Reel
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA48PACCUR, ATMEGA48PA CCUR
На английском языке: Datasheet ATMEGA48PA-CCUR - Atmel Microcontrollers (MCU) AVR 4 Kb FLSH 256B EE 512B SRAM-20MHz IND
