Datasheet ATMEGA168PA-CCU - Atmel Даташит Микроконтроллеры (MCU) AVR 16 Кб FL 512B EE 1 Кб SRAM-20MHz — Даташит
Наименование модели: ATMEGA168PA-CCU
Купить ATMEGA168PA-CCU на РадиоЛоцман.Цены — от 64 до 228 ₽13 предложений от 13 поставщиков IC MCU 8BIT 16KB FLASH 32UFBGA. AVR AVR® ATmega Microcontroller IC 8-Bit 20MHz 16KB (8K x 16) FLASH 32-UFBGA (4x4). Embedded... | |||
| ATMEGA168PA-CCU Microchip | 131 ₽ | ||
| ATMEGA168PA-CCU Atmel | по запросу | ||
| ATMEGA168PA-CCU Microchip | по запросу | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 16 Кб FL 512B EE 1 Кб SRAM-20MHz
Features
· High Performance, Low Power Atmel®AVR® 8-Bit Microcontroller · Advanced RISC Architecture
131 Powerful Instructions Most Single Clock Cycle Execution 32 x 8 General Purpose Working Registers Fully Static Operation Up to 20 MIPS Throughput at 20MHz On-chip 2-cycle Multiplier High Endurance Non-volatile Memory Segments 4/8/16/32KBytes of In-System Self-Programmable Flash program memory 256/512/512/1KBytes EEPROM 512/1K/1K/2KBytes Internal SRAM Write/Erase Cycles: 10,000 Flash/100,000 EEPROM Data retention: 20 years at 85°C/100 years at 25°C(1) Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation Programming Lock for Software Security Atmel® QTouch® library support Capacitive touch buttons, sliders and wheels QTouch and QMatrix® acquisition Up to 64 sense channels Peripheral Features Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode One 16-bit Timer
- Шина данных: 8 бит
- Ядро: AVR
- RoHS: да
ATMEGA168PACCU, ATMEGA168PA CCU
