Datasheet ATMEGA8515L-8AUR - Atmel Даташит Микроконтроллеры (MCU) AVR 8 Кб FLSH 512B EE 512B SRAM-8MHz, IND — Даташит
Наименование модели: ATMEGA8515L-8AUR
34 предложений от 16 поставщиков
Микросхема Микроконтроллер, AVR, 8KB FLASH, 512B EE, 512B SRAM - 8MHz, TQFP, IND TEMP, GREEN, T&R
ATMEGA8515L-8AUR
70 ₽
Триема
ATMEGA8515L-8AUR
710 ₽
ATMEGA8515L-8AUR
Atmel
ATMEGA8515L-8AUR
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 8 Кб FLSH 512B EE 512B SRAM-8MHz, IND
data sheetСкачать Data Sheet
Features
· High-performance, Low-power AVR® 8-bit Microcontroller · RISC Architecture
­ 130 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 16 MIPS Throughput at 16 MHz ­ On-chip 2-cycle Multiplier Nonvolatile Program and Data Memories ­ 8K Bytes of In-System Self-programmable Flash Endurance: 10,000 Write/Erase Cycles ­ Optional Boot Code Section with Independent Lock bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ 512 Bytes EEPROM Endurance: 100,000 Write/Erase Cycles ­ 512 Bytes Internal SRAM ­ Up to 64K Bytes Optional External Memory Space ­ Programming Lock for Software Security Peripheral Features ­ One 8-bit Timer/Counter with Separate Prescaler and Compare Mode ­ One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode ­ Three PWM Channels ­ Programmable Serial USART ­ Master/Slave SPI Serial Interface ­ Programmable Watchdog Timer w
  • Упаковка: Reel
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA8515L8AUR, ATMEGA8515L 8AUR
На английском языке: Datasheet ATMEGA8515L-8AUR - Atmel Microcontrollers (MCU) AVR 8 Kb FLSH 512B EE 512B SRAM-8MHz, IND
