Datasheet ATMEGA32A-MUR - Atmel Даташит Микроконтроллеры (MCU) AVR 32 Кб FLSH 1 Кб EE 2 Кб SRAM-16MHZ — Даташит
Наименование модели: ATMEGA32A-MUR
![]() 24 предложений от 13 поставщиков Микросхема Микроконтроллер, AVR, 32KB FLASH, 1KB EE, 2KB SRAM - 16MHz, QFN/MLF, IND TEMP, GREEN, T&R | |||
ATMEGA32A-MUR Atmel | 215 ₽ | ||
ATMEGA32A-MUR Atmel | 379 ₽ | ||
ATMEGA32A-MUR Atmel | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 32 Кб FLSH 1 Кб EE 2 Кб SRAM-16MHZ
Features
· High-performance, Low-power AVR® 8-bit Microcontroller · Advanced RISC Architecture
131 Powerful Instructions Most Single-clock Cycle Execution 32 x 8 General Purpose Working Registers Fully Static Operation Up to 16 MIPS Throughput at 16 MHz On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments 32K Bytes of In-System Self-programmable Flash program memory 1024 Bytes EEPROM 2K Byte Internal SRAM Write/Erase Cycles: 10,000 Flash/100,000 EEPROM Data retention: 20 years at 85°C/100 years at 25°C(1) Optional Boot Code Section with Independent Lock Bits · In-System Programming by On-chip Boot Program · True Read-While-Write Operation Programming Lock for Software Security JTAG (IEEE std.
1149.1 Compliant) Interface Boundary-scan Capabilities According to the JTAG Standard Extensive On-chip Debug Support Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface Peripheral Features Two 8-bit Timer/Counters with
- Упаковка: Reel
- Шина данных: 8 бит
- Ядро: AVR
- RoHS: да
ATMEGA32AMUR, ATMEGA32A MUR
