Datasheet ATTINY20-CCUR - Atmel Даташит Микроконтроллеры (MCU) AVR 2 Кб FL 128B SRAM ADC 2T-12MHz, IND — Даташит
Наименование модели: ATTINY20-CCUR
20 предложений от 13 поставщиков
Микросхема Микроконтроллер, MCU 8Bit ATtiny AVR RISC 2KB Flash 2.5V/3.3V/5V 15Pin UFBGA T/R
ATTINY20-CCUR
Atmel
50 ₽
ATTINY20-CCUR
от 84 ₽
ATTINY20-CCUR
Atmel
ATTINY20-CCUR
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 2 Кб FL 128B SRAM ADC 2T-12MHz, IND
data sheetСкачать Data Sheet
Features
· High Performance, Low Power AVR® 8-bit Microcontroller · Advanced RISC Architecture
­ 112 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 16 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 12 MIPS Throughput at 12 MHz Non-volatile Program and Data Memories ­ 2K Bytes of In-System Programmable Flash Program Memory ­ 128 Bytes Internal SRAM ­ Flash Write/Erase Cycles: 10,000 ­ Data Retention: 20 Years at 85oC / 100 Years at 25oC Peripheral Features ­ One 8-bit Timer/Counter with Two PWM Channels ­ One 16-bit Timer/Counter with Two PWM Channels ­ 10-bit Analog to Digital Converter · 8 Single-ended Channels ­ Programmable Watchdog Timer with Separate On-chip Oscillator ­ On-chip Analog Comparator ­ Master/Slave SPI Serial Interface ­ Slave TWI Serial Interface Special Microcontroller Features ­ In-System Programmable ­ External and Internal Interrupt Sources ­ Low Power Idle, ADC Noise Reduction, Stand-by and Power-down Modes ­ Enhanced Power-o
  • Упаковка: Reel
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATTINY20CCUR, ATTINY20 CCUR
На английском языке: Datasheet ATTINY20-CCUR - Atmel Microcontrollers (MCU) AVR 2 Kb FL 128B SRAM ADC 2T-12MHz, IND
