Datasheet ATMEGA644P-20MQR - Atmel Даташит Микроконтроллеры (MCU) AVR 64K FLSH 4K SRAM 2 Кб EE-20MHz EXT, 5 В — Даташит
Наименование модели: ATMEGA644P-20MQR
Микросхема Микроконтроллер, AVR 64K FLASH 4K SRAM, 2KB EEPROM - 20MHz, QFN/MLF, EXT TEMP, GREEN, 5V, T&R
ATMEGA644P-20MQR
177 ₽
ATMEGA644P-20MQR
319 ₽
IC Home
ATMEGA644P-20MQR
535 ₽
ATMEGA644P-20MQR
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 64K FLSH 4K SRAM 2 Кб EE-20MHz EXT, 5 В
data sheetСкачать Data Sheet
Features
· High-performance, Low-power Atmel® AVR® 8-bit Microcontroller · Advanced RISC Architecture
­ 131 Powerful Instructions ­ Most Single-clock Cycle Execution ­ 32 Ч 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 20 MIPS Throughput at 20 MHz ­ On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments ­ 16K/32K/64K Bytes of In-System Self-programmable Flash program memory ­ 512B/1K/2K Bytes EEPROM ­ 1K/2K/4K Bytes Internal SRAM ­ Write/Erase Cycles: 10,000 Flash/ 100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ Programming Lock for Software Security JTAG (IEEE std.
1149.1 Compliant) Interface ­ Boundary-scan Capabilities According to the JTAG Standard ­ Extensive On-chip Debug Support ­ Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface Peripheral Features ­ Two 8
  • Упаковка: Reel
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA644P20MQR, ATMEGA644P 20MQR
На английском языке: Datasheet ATMEGA644P-20MQR - Atmel Microcontrollers (MCU) AVR 64K FLSH 4K SRAM 2 Kb EE-20MHz EXT, 5 V
