Datasheet AT91SAM9G45-CU-999 - Atmel Даташит Микроконтроллеры (MCU) IND TEMP MRL А — Даташит
Наименование модели: AT91SAM9G45-CU-999
Микросхема Микроконтроллер, MCU 32Bit ARM926EJ-S RISC 64KB ROM 1.8V/3.3V Automotive 324Pin TFBGA
AT91SAM9G45-CU-999
65 ₽
AT91SAM9G45-CU-999
Atmel
4 219 ₽
IC Home
AT91SAM9G45-CU-999
AT91SAM9G45-CU-999
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) IND TEMP MRL А
data sheetСкачать Data Sheet
Features
· 400 MHz ARM926EJ-STM ARM® Thumb® Processor
­ 32 KBytes Data Cache, 32 KBytes Instruction Cache, MMU
· Memories
­ DDR2 Controller 4-bank DDR2/LPDDR, SDRAM/LPSDR ­ External Bus Interface supporting 4-bank DDR2/LPDDR, SDRAM/LPSDR, Static Memories, CompactFlash, SLC NAND Flash with ECC ­ One 64-KByte internal SRAM, single-cycle access at system speed or processor speed through TCM interface ­ One 64-KByte internal ROM, embedding bootstrap routine Peripherals ­ LCD Controller supporting STN and TFT displays up to 1280*860 ­ ITU-R BT.
601/656 Image Sensor Interface ­ USB Device High Speed, USB Host High Speed and USB Host Full Speed with OnChip Transceiver ­ 10/100 Mbps Ethernet MAC Controller ­ Two High Speed Memory Card Hosts (SDIO, SDCard, MMC) ­ AC'97 controller ­ Two Master/Slave Serial Peripheral Interfaces ­ Two Three-channel 16-bit Timer/Counters ­ Two Synchronous Serial Controllers (I2S mode) ­ Four-channel 16-bit PWM Controller ­ Two Two-wire Interfaces ­ Four USARTs wi
  • Упаковка: Reel
  • Шина данных: 32 бит
AT91SAM9G45CU999, AT91SAM9G45 CU 999
На английском языке: Datasheet AT91SAM9G45-CU-999 - Atmel Microcontrollers (MCU) IND TEMP MRL A
