Datasheet ATMEGA3250P-20AUR - Atmel Даташит Микроконтроллеры (MCU) AVR 32K FLSH 2K SRAM 1 Кб EE-20MHz IND, 5 В — Даташит
Наименование модели: ATMEGA3250P-20AUR
Микросхема Микроконтроллер, AVR 32K FLASH 2K SRAM, 1KB EEPROM - 20MHz,TQFP, IND TEMP,GREEN, 5V, T&R
ATMEGA3250P-20AUR
142 ₽
ATMEGA3250P-20AUR
Atmel
343 ₽
ATMEGA3250P-20AUR
ATMEGA3250P-20AUR
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 32K FLSH 2K SRAM 1 Кб EE-20MHz IND, 5 В
data sheetСкачать Data Sheet
Features
· High Performance, Low Power AVR® 8-Bit Microcontroller · Advanced RISC Architecture
­ 130 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 20 MIPS Throughput at 20 MHz ­ On-Chip 2-cycle Multiplier High Endurance Non-volatile Memory segments ­ 32K Bytes of In-System Self-programmable Flash program memory ­ 1K Bytes EEPROM ­ 2K Bytes Internal SRAM ­ Write/Erase cyles: 10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/100 years at 25°C(1) ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ Programming Lock for Software Security JTAG (IEEE std.
1149.1 compliant) Interface ­ Boundary-scan Capabilities According to the JTAG Standard ­ Extensive On-chip Debug Support ­ Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface Peripheral Features ­ Two 8-bit Timer/Counters with Separa
  • Упаковка: Reel
  • Шина данных: 8 бит
  • Ядро: AVR
ATMEGA3250P20AUR, ATMEGA3250P 20AUR
На английском языке: Datasheet ATMEGA3250P-20AUR - Atmel Microcontrollers (MCU) AVR 32K FLSH 2K SRAM 1 Kb EE-20MHz IND, 5 V
