Datasheet AT32UC3A0512-ALTTA - Atmel Даташит Микроконтроллеры (MCU) UC3A0 512 Кб flash -40/+85DEG AUTO — Даташит
Наименование модели: AT32UC3A0512-ALTTA
Микросхема Микроконтроллер, MCU 32Bit AT32 AVR RISC 512KB Flash 1.8V/3.3V Automotive 144Pin LQFP Tray
AT32UC3A0512-ALTTA
861 ₽
AT32UC3A0512-ALTTA
Atmel
866 ₽
AT32UC3A0512-ALTTA
AT32UC3A0512-ALTTA
Производитель: Atmel
Описание: Микроконтроллеры (MCU) UC3A0 512 Кб flash -40/+85DEG AUTO
data sheetСкачать Data Sheet
Features
· High Performance, Low Power 32-Bit Atmel® AVR® Microcontroller
­ Compact Single-cycle RISC Instruction Set Including DSP Instruction Set ­ Read-Modify-Write Instructions and Atomic Bit Manipulation ­ Performing 1.49 DMIPS / MHz Up to 91 DMIPS Running at 66 MHz from Flash (1 Wait-State) Up to 49 DMIPS Running at 33MHz from Flash (0 Wait-State) ­ Memory Protection Unit Multi-hierarchy Bus System ­ High-Performance Data Transfers on Separate Buses for Increased Performance ­ 15 Peripheral DMA Channels Improves Speed for Peripheral Communication Internal High-Speed Flash ­ 512K Bytes, 256K Bytes, 128K Bytes Versions ­ Single Cycle Access up to 33 MHz ­ Prefetch Buffer Optimizing Instruction Execution at Maximum Speed ­ 4ms Page Programming Time and 8ms Full-Chip Erase Time ­ 100,000 Write Cycles, 15-year Data Retention Capability ­ Flash Security Locks and User Defined Configuration Area Internal High-Speed SRAM, Single-Cycle Access at Full Speed ­ 64K Bytes (512KB and 256KB Fla
  • Упаковка: Tray
  • Шина данных: 32 бит
AT32UC3A0512ALTTA, AT32UC3A0512 ALTTA
На английском языке: Datasheet AT32UC3A0512-ALTTA - Atmel Microcontrollers (MCU) UC3A0 512 Kb flash -40/+85DEG AUTO
