Datasheet MAX9203ESA+ - Maxim Даташит ИС, HIGH SPEED COMP, одиночный, 7 нс, SOIC-8 — Даташит
Наименование модели: MAX9203ESA+
![]() 47 предложений от 23 поставщиков Микросхема Компаратор, Analog Comparator, Low Power, High Speed, 1, 7ns, 5V to 10V, ± 4.75V to ± 5.25V, NSOIC, 8Pins | |||
MAX9203ESA+ Maxim | от 166 ₽ | ||
MAX9203ESA Maxim | по запросу | ||
MAX9203ESA+ | по запросу | ||
MAX9203ESA Analog Devices | по запросу |
Производитель: Maxim
Описание: ИС, HIGH SPEED COMP, одиночный, 7 нс, SOIC-8
19-1936; Rev 1; 1/05
Low-Cost, 7ns, Low-Power Voltage Comparators
General Description
The MAX9201/MAX9202/MAX9203 high-speed, lowpower, quad/dual/single comparators feature TTL logic outputs with active internal pullups.
Fast propagation delay (7ns typ at 5mV overdrive) makes these devices ideal for fast A/D converters and sampling circuits, line receivers, V/F converters, and many other data-discrimination, signal restoration applications. All comparators can be powered from separate analog and digital power supplies or from a single combined supply voltage. The analog input common-mode range includes the negative rail, allowing ground sensing when powered from a single supply. The MAX9201/ MAX9202/MAX9203 consume only 9mW per comparator when powered from a +5V supply. The MAX9202/MAX9203 feature output latches with TTL compatible inputs. The comparator output states are held when the latch inputs are driven low. The MAX9201 provides all the same features as the MAX9202/MAX9203 with
- Output Compatibility: TTL
- Время отклика: 7 нс
- Диапазон напряжения питания: 5 В ... 10 В, ± 4.75 В ... ± 5.25 В
- Количество компараторов: 1
- Тип выхода: TTL
- Тип компаратора: High Speed
- Ток потребления: 1.3 мА
- RoHS: да
