Datasheet ATSAM4S16CA-CFU - Atmel Даташит Микроконтроллеры (MCU) VFBGA, GREEN, IND TEMP, MRL А — Даташит
Atmel ATSAM4S16CA-CFU
Наименование модели: ATSAM4S16CA-CFU
Микросхема Микроконтроллер, MCU 32Bit SAM4S ARM Cortex M4 RISC 1024KB Flash 1.2V/3.3V 100Pin VFBGA Tray
ATSAM4S16CA-CFU
Atmel
649 ₽
ATSAM4S16CA-CFU
Atmel
ATSAM4S16CA-CFU
Atmel
Hi-Tech Circuit Group
ATSAM4S16CA-CFU
Производитель: Atmel
Описание: Микроконтроллеры (MCU) VFBGA, GREEN, IND TEMP, MRL А
data sheetСкачать Data Sheet
Features
· Core
­ ARM® Cortex®-M4 with a 2Kbytes cache running at up to 120 MHz ­ Memory Protection Unit (MPU) ­ DSP Instruction Set ­ Thumb®-2 instruction set Pin-to-pin compatible with SAM3N, SAM3S products (64- and 100- pin versions) and SAM7S legacy products (64-pin version) Memories ­ Up to 2048 Kbytes embedded Flash with optional dual bank and cache memory ­ Up to 160 Kbytes embedded SRAM ­ 16 Kbytes ROM with embedded boot loader routines (UART, USB) and IAP routines ­ 8-bit Static Memory Controller (SMC): SRAM, PSRAM, NOR and NAND Flash support System ­ Embedded voltage regulator for single supply operation ­ Power-on-Reset (POR), Brown-out Detector (BOD) and Watchdog for safe operation ­ Quartz or ceramic resonator oscillators: 3 to 20 MHz main power with Failure Detection and optional low-power 32.768 kHz for RTC or device clock ­ RTC with Gregorian and Persian Calendar mode, waveform generation in lowpower modes ­ RTC clock calibration circuitry for 32.768 kHz crystal frequen
  • Вид монтажа: SMD/SMT
  • Встроенный в чип АЦП: да
  • Рабочий диапазон температрур: - 40 C ...
    + 105 C
  • Размер ОЗУ: 128 Кб
  • Размер памяти программ: 1024 Кб
  • Серия процессора: AT91SAM
  • Тактовая частота максимальная: 120 МГц
  • Тип корпуса: QFN-100
  • Шина данных: 32 бит
  • Ядро: ARM Cortex M4
ATSAM4S16CACFU, ATSAM4S16CA CFU
На английском языке: Datasheet ATSAM4S16CA-CFU - Atmel Microcontrollers (MCU) VFBGA, GREEN, IND TEMP, MRL A
