Datasheet Texas Instruments MSP430FR5731IDAR — Даташит
СерияMSP430FR5731
МодельMSP430FR5731IDAR
MSP430FR5731 Микроконтроллер ULP, 24 МГц, 4 КБ FRAM, 1 КБ SRAM, 32 ввода-вывода, 10-разрядный АЦП и компаратор 38-TSSOP от -40 до 85
MSP430FR573x Mixed-Signal Microcontrollers datasheet
PDF, 2.3 Мб, Версия: K, Файл опубликован: 25 апр 2016
Pin38
Package TypeDA
Industry STD TermTSSOP
Package QTY2000
МаркировкаM430FR5731
Width (мм)6.2
Length (мм)12.5
Thickness (мм)1.15
Max Height (мм)1.2
ADCADC10 - 12ch
AESN/A
Active Power91.667 uA/MHz
Additional FeaturesReal-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA
BSLUART
CPUMSP430
Comparators16
DMA3
Featuredfr5
Тактовая частота24 МГц
GPIO Pins32
I2C1
Max VCC3.6
Min VCC2
Multiplier32x32
Non-volatile Memory4 KB
Package GroupTSSOP
Package Size: mm2:W x L38TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
RAM1 KB
SPI3
Security EnablerCryptographic acceleration,Debug security,Physical security,Secure FW and SW update,Software IP protection
Special I/ON/A
Standby Power6.4 LPM3-uA
Timers - 16-bit5
UART2
Wakeup Time78 us
  • Evaluation Modules & Boards: MSP-TS430RHA40A
    MSP-TS430RHA40A- 40-pin Target Development Board for MSP430FRxx FRAM MCUs
  • Evaluation Modules & Boards: MSP-FET430U40A
    40-pin Target Development Board and MSP-FET Programmer Bundle for MSP430F5x MCUs
    MSP EnergyTrace Technology
  • Over-the-Air (OTA) Update With the MSP430FR57xx (Rev. A)
    PDF, 3.5 Мб, Версия: A, Файл опубликован: 2 мар 2015
  • MSP430 System-Level ESD Considerations
    PDF, 1.5 Мб, Файл опубликован: 29 мар 2012
    System-Level ESD has become increasingly demanding with silicon technology scaling towards lower voltages and the need for designing cost-effective and ultra-low power components. This application report addresses three different ESD topics to help board designers and OEMs understand and design robust system-level designs:(1) Component-level ESD testing and system-level ESD testing, their differ
  • Maximizing Write Speed on the MSP430в„ў FRAM (Rev. B)
    PDF, 103 Кб, Версия: B, Файл опубликован: 4 фев 2015
    Nonvolatile low-power ferroelectric RAM (FRAM) is capable of extremely high-speed write accesses. This application report discusses how to maximize FRAM write speeds specifically in the MSP430FRxx family using simple techniques. The document uses examples from bench tests performed on the MSP430FR5739 device, which can be extended to all MSP430в„ў FRAM-based devices, and discusses tradeoffs such as
  • MSP430 FRAM Technology – How To and Best Practices
    PDF, 326 Кб, Файл опубликован: 23 июн 2014
    FRAM is a non-volatile memory technology that behaves similar to SRAM while enabling a whole host of new applications, but also changing the way firmware should be designed. This application report outlines the how to and best practices of using FRAM technology in MSP430 from an embedded software development perspective. It discusses how to implement a memory layout according to application-specif
  • MSP430 FRAM Quality and Reliability (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 1 май 2014
    FRAM is a nonvolatile embedded memory technology and is known for its ability to be ultra-low power while being the most flexible and easy-to-use universal memory solution available today. This application report is intended to give new FRAM users and those migrating from flash-based applications knowledge on how FRAM meets key quality and reliability requirements such as data retention and endura
  • Migrating from the USCI Module to the eUSCI Module (Rev. A)
    PDF, 41 Кб, Версия: A, Файл опубликован: 13 сен 2012
    The purpose of this application report is to enable easy migration for designs based on the USCI_A and USCI_B modules to the eUSCI_A and the eUSCI_B modules. The document highlights the new features in the eUSCI module and the main differences between the USCI and the eUSCI modules.
  • Migrating from the MSP430F2xx Family to the MSP430FR57xx Family (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 16 фев 2012
    This application report enables easy migration from MSP430F2xx Flash-based MCUs to the MSP430FR57xx family FRAM-based MCU. It covers programming, system, and peripheral considerations when migrating firmware. The purpose is to highlight differences between the two families. For more information on the usage of the MSP430FR57xx features, see the MSP430FR57xx Family User's Guide (
  • General Oversampling of MSP ADCs for Higher Resolution (Rev. A)
    PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
    Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430FRxx FRAM
На английском языке: Datasheet Texas Instruments MSP430FR5731IDAR
