Datasheet ATMEGA8A-AN - Atmel Даташит Микроконтроллеры (MCU) AVR 8 Кб FL 512B EE 1 Кб SRAM 16 МГц GRN — Даташит
Atmel ATMEGA8A-AN
Наименование модели: ATMEGA8A-AN
31 предложений от 18 поставщиков
IC MCU 8BIT 8KB FLASH 32TQFP. AVR AVR® ATmega Microcontroller IC 8-Bit 16MHz 8KB (4K x 16) FLASH 32-TQFP (7x7). Embedded...
ATMEGA8A-AN
187 ₽
ATMEGA8A-AN
Atmel
195 ₽
ATMEGA8A-AN
397 ₽
Hi-Tech Circuit Group
ATMEGA8A-AN
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 8 Кб FL 512B EE 1 Кб SRAM 16 МГц GRN
data sheetСкачать Data Sheet
AVR523: Migration from ATmega8 to ATmega8A
8-bit Microcontrollers
1 Introduction
In order to optimize the manufacturing process and to further reduce current consumption, an optimized version of ATmega8 has been introduced.
The ATmega8A is a functionally identical, drop-in replacement for the ATmega8. All devices are subject to the same qualification process and same set of production tests, but as the manufacturing process is not the same some electrical characteristics differ. ATmega8 and ATmega8A have separate datasheets. This application note outlines the differences between the two devices and the datasheets. There is also a detailed change log to assist the user at the end of the ATmega8A datasheet. Remember to always use the latest revision of the device datasheet. Minor differences in typical characteristics are not discussed in this document as long as the low and high limits remain the same. For detailed information about the typical characteristics, see sections "Electrical
  • Вид монтажа: SMD/SMT
  • Встроенный в чип АЦП: да
  • Рабочее напряжение питания: 2.7 В ... 5.5 В
  • Размер ОЗУ: 1 Кб
  • Размер памяти программ: 8 Кб
  • Серия процессора: ATMEGA8
  • Тактовая частота максимальная: 16 МГц
  • Тип корпуса: TQFP-32
  • Шина данных: 8 бит
  • Ядро: AVR
  • RoHS: да
ATMEGA8AAN, ATMEGA8A AN
На английском языке: Datasheet ATMEGA8A-AN - Atmel Microcontrollers (MCU) AVR 8 Kb FL 512B EE 1 Kb SRAM 16 MHz GRN
