Datasheet ATMEGA164PA-ANR - Atmel Даташит Микроконтроллеры (MCU) AVR 16 Кб FL 512B EE 1 Кб SRAM 20 МГц GRN — Даташит
Наименование модели: ATMEGA164PA-ANR
Купить ATMEGA164PA-ANR на РадиоЛоцман.Цены — от 81 до 985 ₽23 предложений от 15 поставщиков IC MCU 8BIT 16KB FLASH 44TQFP. AVR AVR® ATmega Microcontroller IC 8-Bit 20MHz 16KB (8K x 16) FLASH 44-TQFP (10x10). Embedded... | |||
| ATMEGA164PA-ANR Atmel | 311 ₽ | ||
| ATMEGA164PA-ANR Microchip | от 769 ₽ | ||
| ATMEGA164PA-ANR Atmel | от 985 ₽ | ||
| ATMEGA164PA-ANR Atmel | по запросу | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 16 Кб FL 512B EE 1 Кб SRAM 20 МГц GRN
AVR527: Migrating from ATmega164P/324P/644P to ATmega164PA/324PA/644PA
8-bit Microcontrollers
1 Introduction
In order to optimize the manufacturing process and to further reduce current consumption, an optimized version of ATmega164P/324P/644P has been introduced.
The ATmega164PA/324PA/644PA is a functionally identical, drop-in replacement for the ATmega164P/324P/644P. All devices are subject to the same qualification process and same set of production tests, but as the manufacturing process is not the same some electrical characteristics differ. ATmega164P/324P/644P and ATmega164PA/324PA/644PA have separate datasheets. This application note outlines the differences between the two devices and the datasheets. There is also a detailed change log to assist the user at the end of the ATmega164PA/324PA/644PA datasheet. Remember to always use the latest revision of the device datasheet. Minor differences in typical characteristics are not discussed in this document as long as the low and h
- Вид монтажа: SMD/SMT
- Встроенный в чип АЦП: да
- Рабочее напряжение питания: 1.8 В ... 5.5 В
- Размер ОЗУ: 1 Кб
- Размер памяти программ: 16 Кб
- Серия процессора: ATMEGA164
- Тип корпуса: TQFP-44
- Шина данных: 8 бит
- Ядро: AVR
- RoHS: да
ATMEGA164PAANR, ATMEGA164PA ANR
