Datasheet ATSAM3N00BA-MU - Atmel Даташит Микроконтроллеры (MCU) QFN, GREEN, IND TEMP, MRL А — Даташит
Наименование модели: ATSAM3N00BA-MU
18 предложений от 17 поставщиков
Микросхема Микроконтроллер, MICROCHIP ATSAM3N00BA-MU 32Bit Microcontroller, SAM3N Series, ARM Cortex-M3, 48MHz, 16KB, 4KB, 64Pins, QFN
ATSAM3N00BA-MU
79 ₽
ATSAM3N00BA-MU
234 ₽
Элитан
ATSAM3N00BA-MU
279 ₽
Hi-Tech Circuit Group
ATSAM3N00BA-MU
Производитель: Atmel
Описание: Микроконтроллеры (MCU) QFN, GREEN, IND TEMP, MRL А
data sheetСкачать Data Sheet
Features
· Core
­ ARM® Cortex®-M3 revision 2.0 running at up to 48 MHz ­ Thumb®-2 instruction ­ 24-bit SysTick Counter ­ Nested Vector Interrupt Controller Pin-to-pin compatible with SAM7S legacy products (48- and 64-pin versions) and SAM3S (48-, 64- and 100-pin versions) Memories ­ From 16 to 256 Kbytes embedded Flash, 128-bit wide access, memory accelerator, single plane ­ From 4 to 24 Kbytes embedded SRAM ­ 16 Kbytes ROM with embedded bootloader routines (UART) and IAP routines System ­ Embedded voltage regulator for single supply operation ­ Power-on-Reset (POR), Brown-out Detector (BOD) and Watchdog for safe operation ­ Quartz or ceramic resonator oscillators: 3 to 20 MHz main power with Failure Detection and optional low power 32.768 kHz for RTC or device clock ­ High precision 8/12 MHz factory trimmed internal RC oscillator with 4 MHz default frequency for device startup.
In-application trimming access for frequency adjustment ­ Slow Clock Internal RC oscillator as permanent low
  • Тактовая частота максимальная: 48 МГц
  • Шина данных: 32 бит
  • RoHS: да
ATSAM3N00BAMU, ATSAM3N00BA MU
На английском языке: Datasheet ATSAM3N00BA-MU - Atmel Microcontrollers (MCU) QFN, GREEN, IND TEMP, MRL A
